As i told - its pstate bug, when CPU freeze at same Pstate doesnt matter what u do. When u rebooting this Pstate reset and they changing again under load. So b4 u ran benches at 2.2 for example (depends of yr pstate settings) and now at 3.85man these things are flaky, reset it and entered the exact same settings again and i get 1674 in cinebench now.... right not touching it again![]()
hiya mate ive just read a PM to me over on asrock support forum from a helpful guy called tooqikdatonyb, 2 sticks single rank b-die 8GB each. This BIOS still dont have command rate settings, so i cant try 2T for higher clock![]()
mem back down to 3466 but at cl14 will play more later need to go out
Actually i see nothing on this picture. Can u upload better image?yeah running it nowmem back down to 3466 but at cl14 will play more later need to go out
yay now running 3600 cl14 ..changed nothing cept took mem voltage to 1.42...
<a href="https://ibb.co/b8keOF"><img src="https://thumb.ibb.co/b8keOF/ram_3600.jpg" alt="ram_3600" border="0"></a>
Yea ik that, but in 2.34 those settings not accessible. Maybe they added it properly in 2.36?Advanced/AMD CBS/UMC Common Options/DDR4 Common Options/DRAM Controller Configuration
there you will find command rate auto/2t/1t
credit to tooqik from asrock support forum![]()
I just upgraded to 2.36 and installed 4x8GB of G.Skill TridentZ RGB 3200C14 RAM and it recognizes all 32GB but only running at 1866Mhz. Same as before.
Edit: I also have an issue that when I enable XMP 2.0 and select 3200 or 3333 that my PC will power on and off again 3 or 4 times before it successfully boots.
Hi,to all.hiya mate ive just read a PM to me over on asrock support forum from a helpful guy called tooqik
basically he reads this forum but hasnt registered as hes in OZ
he asked me to tell you there is command rate setting in new beta bios
but its in a different place heres the path he sent me to pass onto yourself
ryzen 5 have average worse OC than ryzen 7 - tested many times. Many ryzen 5 owners report that they cant even achieve 3200 RAM with samsung b-die. And 3.9 max CPU clock seems to be very common too.Hi,to all.
I am new owner of taichi/R5 1600.Im not lucky with silicon lottary.i only managed 3.85 with 1.38.At 4 ghz even with 1.45 i get black screen instant,soc 1.125.offset/llc level 1.Even in bios i get freeze.i m with latest 2.36.i successful run 2933 my g skill aegis 3000 since 2.30 which i flash first time.With 2.34 i got first at 3066 with soc 1.1,ddr 1.40.command rate 1T.when i change to 2T it doesnt apply,still been in 1T always in both bioses 2.34-2.36.Also p state oc is problematic.3400/3500/3600/3700 etc does not work ,only with clocks like 3425/3450 etc.i have ryzen power profil with minimul core 20%.in 2.34 when i set 3066 mem it was display 2133 but run 3066 in 2.36 fixed.I think with 2.36 i get more difficult to oc memory ,get stable,with 2.34 i got 3200 with loose timings,soc 1.125,ddr4 1.425 with 2.36 i get training fail get back to 2133.Mixed feelings about my new setup i was expecting more performance going from fx8320.Sorry for my english,not my native language.
I my gpu bottleneck 290x,so i have the same fps in most games.only in dirt i got huge boost,in batman mins improved from 48 to 60.Yes i have improvement but not a huge spent 630€ replacing major parts.Yes with same money i would get a gtx1080 getting most from fx8320 in 1440pryzen 5 have average worse OC than ryzen 7 - tested many times. Many ryzen 5 owners report that they cant even achieve 3200 RAM with samsung b-die. And 3.9 max CPU clock seems to be very common too.
My mobo a same (dont have access to CR2), so its not my case actually, but bug. Same for CL11/13/15/17/19. How can u get same performance against 8320? ryzen 7 have 2.4 more performance against 8320, so in yr case it should more than x1.5 boost
in my case need to use DRAM voltage 1.37 or above for 3333+ and SOC 1.15 or above. If u want it stableI've got my R5 1600 at 3.8Ghz 1.3v, I haven't tried a lower voltage yet.
I'm using Gskill Ripjaw 3600 17-18-18-38 memory. I can boot into windows using the XMP profile at 3466 but it doesn't last very long. Currently running 3200 with 14-14-14-36 which seems stable![]()
Thanks, will try later![]()
Which is max safe value for Soc?in my case need to use DRAM voltage 1.37 or above for 3333+ and SOC 1.15 or above. If u want it stable
what about 3733? I cant get anything above 3600.soc .. 1.2 is as far as I've gone .. pushed dram to 1.55 trying to get 3800 .. din't work
now heres a question for others out there ..
is there any advantage to run oc in p state ?? atm I'm at 4ghz 3600mem .. the old way ..
