Disc will be fine, just the front that may be a problem even for a little pipsqueak like you![]()
Ha, I went out this morning and it wasn't so bad in terms of handling but I really didn't enjoy it that much! Sick of this wind.
This ride? Good going but I did notice your average cadence was quite low with a large suffer score. To me that could indicate you're grinding lots on the flat (not many climbs there) and probably overly tiring yourself? Try dropping a gear or two to increase your cadence, you'll find the lower muscle strain eases some of your recovery time and lowers fatigue. I could be wrong, the power profile looks like you were freewheeling/easy spinning for lots of it, even though the suffer score is huge (incorrectly set HR zones would also cause this)? Ben commented about your HR being lower than your recovery - when your HR was low your cadence was also low, when your HR was higher (pushing on!) your cadence was much higher and more consistent... I guess what I'm trying to say is - maintaining a more consistent cadence, regardless of the effort/power you're putting out should lower your overall fatigue and recovery requirements. There's less power 'spikes' when you're picking up speed.My first experience of riding in heavy winds last night mixed with a couple of light showers. Not a pleasant experience![]()
Weather next week is looking better too! Jealous of the free breakfasts!Woohoo, it's bike to work week next week which means free breakfasts in the cafe for cyclists. Sausage sandwiches ahoy!!
Yeah the flat top tube does also look much thicker. The dropped seatstays is a current trend for many of the aero and endurance models (like the Venge) but the downtube remains mostly unchanged (which is obviously quite distinctive on the Venge). They should've made it more in line with the Venge, as like you say I think at the moment it looks very similar to the Road/Teammachine, Canyon Aeroad/Endurace, Scott Foil, Cervelo S3 and even more like the Specialized Roubaix than it did before.The frame looks just like the BMC Team Machine. I prefer the flat swooping top tube look of the current model.
I'd look at your hub, there shouldn't be enough 'flex' in the rear stays for the dropouts to move outside of the hub sides onto the skewers unless the frame has bent outwards?! (or you've lost an endcap from the hub).Second Doh moment! Start to put a bit more power down to climb up a little kick in the road. Hear a large clunk and then my gears are screaming at me. Rode for another mile till I decided to investigate. Turns out my rear wheel had come off and my dropouts where sitting on the skewers. I imagine I've probably caused some severe damage.
Good shout, I hadn't realised Duraace started at 7700 only recalling the change from 7900 to 9000!7xxx - Dura ace 7700, 7800, 7900 > 9000
<snip>
So 7800 has been used before. Don't see the logic in the new ones as the groups in between will go to a number they haven't used before.
) so was a lot of freewheeling and barely moving
I had to keep myself entertained by doing sprints every now and then and trying to get our strongest rider some KOM segementsI'd look at your hub, there shouldn't be enough 'flex' in the rear stays for the dropouts to move outside of the hub sides onto the skewers unless the frame has bent outwards?! (or you've lost an endcap from the hub).
Ahhh, sorry I just recalled looking at the data of that ride & thinking WTF@ the suffer score!No it wasn't that ride, that was last night. Cadence was so slow as it was a group ride and we were with two people averaging 8-10mph (yep...) so was a lot of freewheeling and barely moving
I was referring to this ride. You're right though, need to set up my heart rate zones, I've set my maximum but thats it, not really fine tuned them yet.
The hub should be ok, they're generally very tough! Your frame, chain and cassette will damage easier. The only one I would be concerned about is if your frame is carbon!It's my own fault for not tightening the QR tightly enough. When I say they were sitting on the skewers it would be more apt to say they was sitting on the hubs just above where they should have been.
when your HR was low your cadence was also low, when your HR was higher your cadence was much higher and more consistent...
Anyone log in to Strava using Facebook? I can't login at the moment, it are borked.
Same here, fine as standalone! I've got one 'spam' account (a catchall on an old domain) I sign up to everything with... Then once I'm sure I'm not getting to much spam from (or actually using that website/service), I change to my primary (Gmail) account. Strava is still on my spam account for all the junk it dishes out...I can log in fine using my Strava account. #JustSayin'
Personally I hate linking Facebook, Google, etc with other systems.
Stupid CRC discount through BC not working! Lost connection half way through paying and now won't accept it. I just want some new shoes.
Inboxed you mine, I hardly ever use CRC now so hardly ever use my code!Stupid CRC discount through BC not working! Lost connection half way through paying and now won't accept it. I just want some new shoes.
Edited for youI have Strava set to ping emails to my primary email and I never get anything because I don't have any KOM's worth taking
I'm quite interested to read up on the new Ultegra calipers (ST-R8020) and disc rotors (SM-RT800) to see what they'll offer me over my older 'non-series' calipers (BR-785) and Ice-tech rotors (RT86?). I'm probably slightly more interested in checking the Dura Ace black rotors (9100) in 160mm are 100% compatible (with my 785's) as they look superb with the enclosed heat fins! The calipers will be replacements for my 785's if I ever get a problem (again)...
I'm quite interested to read up on the new Ultegra calipers (ST-R8020) and disc rotors (SM-RT800) to see what they'll offer me over my older 'non-series' calipers (BR-785) and Ice-tech rotors (RT86?). I'm probably slightly more interested in checking the Dura Ace black rotors (9100) in 160mm are 100% compatible (with my 785's) as they look superb with the enclosed heat fins! The calipers will be replacements for my 785's if I ever get a problem (again)...![]()
