- 13 Nov 2009
- Northampton
Great cheers. Have not tried LLC any idea what the equivalent setting in a gigabyte BIOS will be?
Looks like you have a good chip there!
I've never had a Gigabyte AMD board that has LLC
What have you tested those voltages with?
It has it but seems bugged. Just says auto and can't press enter on it to input a value.
Cool rig!
The die under the IHS is the important bit for contact, all CPUs are different assume the block was designed for Ryzen?
Finally got round to fitting the monoblock that arrived last week... Seems pretty decent so far, slightly strange to me the block has a circular contact not covering the whole CPU at the corners though? Or that's normal for the monoblocks (never used one before..)?
Lovely clean looking build
My 4ghz doesn't appear to be realbench stable despite being good in memtest and prime and a full day of gaming yesterday!
Various issues from black screen to lux crashing to fully restarting. Difficult to know whether it's the CPU or the memory so scaling the CPU clock back to see how I get on!
You can bet it will be CPU. Gaming wouldn't load all the cores like realbench does.
The latest version of Prime dosn't load the cpu either. A better option is to run OCCT Linpac with AVX enabled.
Beautiful setup, Smffy
Very nice build @Smffy![]()
Yep breezed through at 3.6/1.25v.
Think I have LLC issues now as going to 1.45v droops the down to the same 1.40 as 1.425 does. Might try the moderate setting out but tbh if 3.9 is doable on sensible volts I'll go for that. At 3.6 my rad fans didn't spin up from 400rpm so complete silence![]()
Thanks, forever updating it but a lot of hard work now done![]()
