Xbox Scorpio
The increase in RAM will be more beneficial if you ask me. 4k res is pointless without 4k textures. This is where Pro struggles as it runs out of RAM. The extra 4GB in X will hopefully see higher res textures being used for the X versions.
that will require a patch, i like to see BF1 running and comparing PS4 Pro to Xbox One X
That's nice but it's not going to be the 4k monster many are thinking it's going to be. Sure it might get close with many of the exclusives, but most Mult-plat games with be on par with ps4 pro or slight improvements if anything. I think people are getting carried away with the Forza 6 port they did onto the scorpio.
In the end i'm getting one anyway as i usually get both and i prefer the black/dark grey case of this one over the white Xbone S case :p
16af only thing PS4 pro can't do system level without a patch
Want it but all I will play is FIFA, lol.
Fifa 17 already 4k native on PS4 Pro, Xbox One X could run on Ultra settings with extra ram
Red Dead Redemption 2 might be proper advantage for XOX. If Rockstar is going to follow their previous strategy, PC version over a year later, the best experience will be on Xbox till then.
What does BF1 run at on Xbone S? 720p or 900p?
If it's 900p then it could possibly get to native 4K. MS said some games at 900p might get to 4K and all 1080p games will. If they are patched. Not just out of the box. Think it runs at 1440p on PS4 Pro.
xbox x is really pointless for any PC gamer in reality.
Especially when the likes of Forza are coming on the PC and will still look and play better depending your PC Hardware
Correct, not aimed at people with £1000+ PC setups. but your still buying games from them anyway :D
the Xbox One version of Battlefield 1 can in some cases reach 1000p, which puts it right next to the PS4 version. This is something of a rare occurrence, however, and only happens during scenes with short draw distances and lower levels of detail.
bf1 will not require a patch for 1080P/60FPS? its dynamic
Yep pc weirdos can stay away and carry on benchmarking their latest and greatest GPU that's 200 times more powerful than any console but games still run like crap as it's poorly optimised so completely pointless.....
yea . i have a 6 core i7 with 32gb RAM and two 980GTX IN SLI mode that still runs well today.
I think if u did not own any PC then a xbox x is a perfect budget PC gaming machine
for me i'm running Mac with only 16GB ram :(
this console works with my setup, i have a reliable computer :) and great gaming machine (console) :D with huge screen :)
Xbox controller and 4K Tv? Which is what I was implying. You don't have to have a monitor.
What about monthly membership and more expensive games?
As for expense.
Gpu (£250), mobo, CPU, RAM (£150) PSU, case and hdd? (£100-120) Can get OS for £10.
Which totals around £500-550.
Now like I said the Scorpio IS decent value. I didn't doubt that.
Erm..I would VERY much like to see the tower only ( which is a huge liberty to remove from expenses), at those prices for components thats built to the same spec and close to the finished form factor.
And Live is what..about £30 a year shopping around, so you can even have 5 years of that and Add £150 to that budget.
5.5GB which will probably put a spanner in the works somewhere.
Don't they take BF1 from PC and turn settings on/off to make sure everything runs? Not going to use PS4 Pro to work out correct settings for xbox x?
i can't see how PS4 Pro going to hold back anything on xbox x
EDIT: Xbox x, so many xxx :(
Well I have a crappy 8 year old laptop which is pretty much an mp3 box so I am excited for this at £450. Will pre-order tomorrow when they are up (Amazon probably).
Pre-orders won't be for a few weeks according to MS as the device does not yet have FCC or CE approval.
Oh I thought I read that it was tomorrow?! Ah well whatever I will pre-order whenever I can! :)
