I was going on the prices mentioned above. Do they vary quite a bit?
Wish I was getting 80Mbps on Infinity 2. I just about get the 55Mbps estimated minimum.
Fine if your connection is fine. If anything goes wrong and you have to phone them, well good luck with that!We had a killer deal with TalkTalk for the last 12 months. We paid the line rental only and got free up to 76Mbps fibre, anytime UK calls (mobiles and landlines). So we paid £18 a month!
Now, TalkTalk have removed their loyalty offers and now charge everyone the same, meaning our best deal is £35 a month for the same as we have now, fixed for 24 months. I've spoken to at least three people and they've offered the same. They've raised a complaint for some reason so maybe they'll do better.
Since we have BT Sport, BT with the cashback works out slightly cheaper than TalkTalk and it's a 12 month contract rather than 24 months.
What are the general views on BT these days?
nice that the home hub has gigaports tho
Thanks mate. Service seems fine at present.
Is there anything complicated in the switching process from TalkTalk to BT? I know it's going from LLU to BTW on the phone side.
Edit:
Placed the order. Should go live 30th June. Hopefully all goes well.
Has anyone managed to set up a VPN with the BT Homehub?
I signed up to IPVanish last night but am struggling to be able to get connected. I installed the app on my Fire TV but when trying to connect it just rotated saying connecting. I’ve read quite a bit suggested BT firmware has issues and the only way around it is a third party router. Can anyone confirm?
If so whats the best option for a router? I remember when I first got my homehub that I struggled getting my old Asus AC66 working so binned it off and sold it.
vdsl status
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 46632000 bps US Actual Rate : 20000000 bps
DS Attainable Rate : 46312424 bps US Attainable Rate : 21992372 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 16 dB Cur SNR Margin : 5 dB
DS actual PSD : 5. 2 dB US actual PSD : 5. 3 dB
NE CRC Count : 37 FE CRC Count : 1254
NE ES Count : 27 FE ES Count : 1147
Xdsl Reset Times : 0 Xdsl Link Times : 2
ITU Version[0] : b5004946 ITU Version[1] : 544e0000
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 18 dB Far SNR Margin : 5 dB
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206
DSLAM CHIPSET VENDOR : < IFTN >
What sort of sync speed should I be getting:
Code:vdsl status ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) ----------- Running Mode : 17A State : SHOWTIME DS Actual Rate : 46632000 bps US Actual Rate : 20000000 bps DS Attainable Rate : 46312424 bps US Attainable Rate : 21992372 bps DS Path Mode : Fast US Path Mode : Fast DS Interleave Depth : 1 US Interleave Depth : 1 NE Current Attenuation : 16 dB Cur SNR Margin : 5 dB DS actual PSD : 5. 2 dB US actual PSD : 5. 3 dB NE CRC Count : 37 FE CRC Count : 1254 NE ES Count : 27 FE ES Count : 1147 Xdsl Reset Times : 0 Xdsl Link Times : 2 ITU Version[0] : b5004946 ITU Version[1] : 544e0000 VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support] Power Management Mode : DSL_G997_PMS_L0 Test Mode : DISABLE -------------------------------- ATU-C Info --------------------------------- Far Current Attenuation : 18 dB Far SNR Margin : 5 dB CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206 DSLAM CHIPSET VENDOR : < IFTN >
Most checks suggest 52 minimum, it's not much, but annoying nonetheless. I guess I must be unlucky have have bad crosstalk. I'm 200 m from the cab as the crow flies, but it's a new build area so the line could take some crazy route for all I know.
