ROG CROSSHAIR VI HERO
Good day everyone.
Is it possible to install the kraken x52 or the corsair 100i v2 without the extra am4 bracket? I have heard at this mainboard u can chose if you install thought am3+ or am4 holes.
That is correct I believe. I am surprised more motherboards did not do this.
Good day everyone.
Yes, the Crosshair VI Hero has mounting holes drilled for both AM3+ and AM4 coolers. Just pop the the AM4 backplate off (be patient when doing this - its new so the adhesive will be quite tacky) and fit the AM3+ in its place.
Ram works in a 7700k system I have, but at 2400mhz speed because it is a dell system.
Hopefully should get the new board tomorrow.
I am tempted to sell ryzen platform and use the 7700k system on a custom build.
If you wanted more stability+reliability then it would definitely make more sense to go for Intel, though to be fair despite all the negativity I've read about Ryzen and the CH6 in particular (e.g. with respect to RAM) I can't say it's all that bad and the multicore performance is definitely a winner in some use cases.
I'm very happy with my rig, sans ASUS lack of frequent driver updates and them conning all of us out for DTS Connect/DD Live in its sound drivers.
Based on a post by Guru3D for RAM compatibility I'd say the CH6 is the worst, and they say get an MSI or ASRock Taichi for best reliability but YMMV. I was running at a 3% overclock and slower RAM. Today I tried to do 3200Mhz Ram and it boots to Windows just fine - but my test (YPi) wouldn't work so I lowered it to 2933Mhz DOCP Standard and it works reliably on BIOS 1201 (I am still waiting for the official ASUS one rather than trying out the beta ones).
Not much luck with these. 2nd CH6 Mobo got as a replacement was clearly a used one and missing parts, reported to Rainforest place and they want me to send it(and the 1st one) back only for a refund and not issuing me with a replacement. I have to place a new order it seems. Seriously considering going for a gigabyte K7.
Your problem is you have the same RAM as me. It is single side Hynix, mine will run at 3066 but occasionally reverts to 2133 at boot up. At 2933 no problems at all. More Ryzen compatible Samsung RAM will run normally at much better speeds.
Currently running at stock on 3200 C14 Ripjaws V 16GB can also use 3333 C16. Compatibility is far better now on 1401 bios (or 1403, but I have not tried that).
This board is hugely better than in April when I purchased it, so probably 3 months of Ryzen testing. Having said that the FX series gave me far more hassles on a CHV.
What's the best bios to put on this board I have r1600 3200mhz 8pack ram coming tomorrow so I need to download.
I had the board in my basket @£245 then it whent up to £260 odd so I took it out whent looking for another one and it was at just over £200 a bargain.
I just updated from 1201, set everything how it was on 1201 and it booted fine. The CPU temp is **** again though, thinks it idles @ 9C, wtf is AMD's problem with that BS offset crap.
You need the AM4 mounting kit for the H100i V2 to fit it to the Crosshair VI. I know this from experience.
The presence of AM3 holes is of no help to fit it.
Ive upgraded my board to 1403, and now my CPU temp stays at 30c all the time. Anyone else had it kill temp monitoring?
