SOME RYZEN 7 1700 OVERCLOCKING!
Caporegime
12 Jul 2007
United Kingdom
You guys should check out the default voltages with stock bios settings and XFR enabled. My 1800X samples all run up to 1.5v at stock when boosting to 4.1Ghz on up to dual threaded workloads.
18 May 2010
London
Why would it be engineered like that when we know that 1.4v ish is enough for 4ghz on all cores (give or take a little in voltage)
29 Jan 2015
West Midlands
Not for sustained periods though.
Its also worth noting that the crosshair likes to overvolt everything.
Maybe you can contact Rob Hallock and ask what the proper stance is to clear some of this up?
Caporegime
12 Jul 2007
United Kingdom
I don't need to, i got these values from the product manager of Ryzen.
Of course you are free to do as you desire though, these are just guidelines based on temperature and the thermal solution you use.
Overclocking voids warranty, so if you are worried run at stock. :)
Probably to ensure each sample has enough voltage to hit that frequency, each CPU sample is slightly different. 4.1Ghz does require significant voltage to run on 8 cores as my testing has discovered. I can hit 4.075Ghz at around 1.5v.
29 Jan 2015
West Midlands
Probably to ensure each sample has enough voltage to hit that frequency, each CPU sample is slightly different. 4.1Ghz does require significant voltage to on 8 cores as my testing has discovered. I can hit 4.075Ghz at around 1.5v+.
I don't doubt you have these numbers from a reliable source, I'm more so questioning why there is different values coming from the same company.
5 Nov 2010
Hertfordshire
Indeed, noticed this right at the start, it's a bit much but i assume it's standard so it'll work for the poorest chips.
As for max recommended on Ryzen, sustained load without extreme cooling you're looking at 1.45v tops. However, most people run less because the wall is big and obvious with Ryzen, a 50MHz increase may cost you as much as 0.1v vcore, which really isn't worth it.
DDR4 1.45v tops is safe. Some Samsung B-Die users are pumping as much as 1.5v through and appears to be fine so far. Extreme overclockers, well, whatever doesn't set it on fire.
Caporegime
12 Jul 2007
United Kingdom
If you look at tech sites when they reviewed Ryzen, it was 1.45v. If you look at the video Rob did, it was 1.425v. Very small difference ( a couple of voltage notches in the bios) which is not going to make any significant change to temperature or power consumption.
Exactly, and you'll see the same behaviour on Radeon GPUs too. (i know you haven't used those for a while Rossi :p)
