Think that’s what's happening as my temp look to be 20C lower than they should be.strange, the temps are moving now but they are pretty low, almost as if the 1700x offset removal has been applied to my 1700 twice!
yeh at idle its cooler than the room temp
With Sense MI Scew disabled the CPU temp does look better but the package temp is 20C higher, maybe that correct? Whats the normal idle package temp?Disable Sense MI Scew.
Temps seem a lot better with it disabled.
I have seen you dancing around campfire with your RAM stick up in the air praying to RNG god.surprising people are having issues with ram speeds still, all i did was set 3200, save and its been fine since day one
What settings did u use to get 3066Mhz?Lets swap RAM and see if you can get mine stable at 3200![]()
3200 with 2*8GB is not a problem, add an extra 2*8G and things change. I have not tried 3200 on the new BIOS so dont know if it will run yet.surprising people are having issues with ram speeds still, all i did was set 3200, save and its been fine since day one
