Caporegime
- 9 Nov 2009
- Planet Earth
Lower hash rate than GPUs but the power efficiency will probably tempt some miners.
Regardless of efficiency, it's a lot easier to have a multi-GPU system than a multi-CPU system. There won't be any Ryzen mining farms.
Anyone use Asus AI Suite? Actually crashes my computer when I try to adjust fan speeds! 3 times in a row, had to reset the bios the last time!
If miners pick this up AMD will be rolling money.
Yes, I am using it, successfully. I only use it to control the fans though.
I imagine this has been posted before but incase it hasn't here it is, a look at Intel's promotional work to deal with Naples which it call's glued together desktop die's.
Desperation or do they have a point?
Ian Cutress said:Intel released a new optimization manual. To get the best local latency, enable on-die NUMA/clustering. 4 NUMA nodes per CPU. Chapter 8.
Kevin Krewill said:That's the same NUMA clustering as EPYC.
Ryan Shrout said:Oh the irony.
I'd be interested how this goes as i'm considering do an upgrade with the same parts.Building a little ryzen system this week, matx 1700 build with a fury x. Be interesting to see how it performs. Ordered 16 gigs corsair lpx 3200 ddr4 which is what i have in my main system hopefully works fine in this. Also hope that gigabyte have some updated bios for the ga-ab350m for better ram speeds.
You know that you have beaten your competition if all that he does is talk about you lol Whole presentation was pretty much desperate smear job
