Post your mobile phone desktop!
10 Aug 2006
Keep mine as minimal as possible, using Lawnchair launcher which is Pixel launcher that allows you to chose custom icons, and chose what grid size you want in the app draw.
29 Jul 2013
A small update
I'm not sure I'm a fan of having a clubcard being the main thing to draw the eye on a home screen :p
Mine isn't exactly creative, the Pixel has made me into a function over form type. Bit of an odd wallpaper today but I use the Google Earth snapshots on cycle so I'll like be better tomorrow :p
7 Mar 2011
Oldham, Lancashire
Using Nokia Z Launcher. But weird coming from Nova but wanted to try something different.
Most used apps automatically on the home screen. Can open others by drawing letters on the screen. Quite like it
23 Feb 2009
Bournemouth
This is on a lenovo p2.
10 Aug 2006
Hmm looks like they stopped developing the app as of May. Well seems I'll be using another loyalty card app now then.
StoCardis my 2nd choice. Android Pay also stores them.
Cheers, i downloaded Stocard as thought that might have been it, Dont use android pay as my bank wont support them.
