Does the game allow you save replays to watch "in-engine"?
I haven't seen an option for it, I use Plays.TV - does a good job and doesn't seem to impact on performance at all.
Last few days I've just been plagued with network lag messages . Any tips on how to sort it out? Or am I just been unlucky and landing on crap servers. ( I tend to mix between EU and NA servers )
Shot in the dark but I never found an answer. Are you able to use plays.tv DVR when in full screen mode?
Yep Virgin, tried a few DNS servers which seem to work for a few hours but then resorts back to lag-city. Usually results in every game ending with lag atm.Virgin Media?
Sadly chances are you can't do anything about it and will just have to wait for it to pass. I had a bad time with them a few weeks ago but resolved itself eventually.
You get all of it. Probably less processing to just send it all rather than on a proximity basis. If you search PUBG ESP you'll see that you have access to all items, players, vehicles, etc across the map.Can anyone with a bit more technical knowledge explain how large multiplayer games like PUBG work?
Like.. there are 100 characters sending data to a server, updating positing and inputs. Server side its calculating the implications of this and sending updates back to clients. But am I receiving full positional etc data on a player that is all the other way on the other side of the map? Or does it LOD in a way?
If any of you are with Virgin, there is a major latency/packet loss problem with all super hub 3 routers, i reckon if any of you are on there big gamer packages, you will have a super hub 3, its a problem with the intel chip in the router, there working on a firmware fix, but its all down to when virgin will roll it out and how quick, and no there aint no fix for it, other than go back to either super hub 1 or 2, like i did.
Cheers. Gone up to 22 and a bit, but got a 5% discount too. Cheers for the heads up.£18.80 on Cdkeys at the moment, might give in.
This explains everything...hacker![]()
.Yeh dont, until at least a firmware update, and thats even if it can be fixed, just google or go to there broadband forums, loads of threads about it, i think some companys that use the intel chip in there routers for there broadband services, have already taken out law suits against them.thanks for this, was about to upgrade. Now I think not.
