- 10 Apr 2006
- North West
Figured out why our electric gate wasn't working and fixed it. Had to buy a new BFT Rigel5 panel, fit, and program new remotes to it. Pleased how easy and painless it was!
Fitted a new induction hob last night
Having to make the cut out in the work surface larger was a right pain! next time I'd pay someone professions to do it for sure
@trimmer1980 very nice transformation, what colour have you painted the wall? Can't work out if it is white or a slightly grey due to the crap laptop screen!!
Also really like the floor, is that a laminate?
Was this a replacement induction hob or a new one to you - If a replacement is it better than the old one - mine is 7 years old and was thinking of replacing it but need to know if there is a major difference in performance - ie touch controls are better - heat up is quicker etc.
Hi there, thankyou, the walls I mixed myself its actually a Homebase tester pot called black magic with white soft sheen paint as it seemed cheaper to do it that way. The floor is Schreiber laminate flooring from home base. They had a deal on so snapped it up.
Annoyingly i then came to fit the middle diagonal piece and the clamps must've been on a slight angle as the whole lot came apart. I'm starting to think Gorilla wood glue isn't actually very good!
