Permabanned
- 23 Apr 2014
- Hertfordshire
Deleted, probably wrong thread......too many random Ryzen threads....
I honestly don't see the problem with a lower end 2C/4T CPU - in that segment IGP performance will be very important for a lot of the sales AMD will make. The issue with the older APUs was:
1.)No upgrade path to higher performance CPUs
2.)The higher TDP variants could consume a decent amount more power than a Core i3
3.)ST performance was much lower
4.)The platform was starting to look dated
5.)The ones we could buy for DIY builds were behind Intel for media decoding duties(BR and SR have updated media functionality)
A 2C/4T Ryzen CPU will not have any of those disadvantages.
OFC,there is a possibility AMD might offer quad cores under £100 but these would need to be differentiated from the Ryzen 3 CPUs,so that might mean things like L3 cache being removed.
They certainly have their uses (I'm using the g4560) but it would be great to see 2C4T pushed so far down the product stack that it facilitates mainstream PC laptop/desktop to adopt 4/6 cores as a standard configuration.
Since Intel's pentium's start around £40 for 2C/2T+igp it would be great to see them introduce 2C/4T+igp (by default more capable igp) at that price point or lower.
If you look at the first $100 quad core it was the Athlon II X4 620,so the Ryzen 3 1200 seems very close to that price point,so you could argue that Ryzen 3 is already at a mainstream price point!!
Having said that the L3 cache takes up 16mm2(plus the 44mm2 for a single CCX),so if they remove the L3 cache like previous AMD APUs,they could technically still have a quad core under £100.
Gigabyte Gaming B350 Gaming 3
1700
Team Group Dark 2x4gb.
No overclock
Failing to boot, 4 diagnostic LEDs just cycle from RAM back to CPU and fails to post. Tried both sticks of ram in all 4 slots to no avail.
Dead RAM?
Well definitely not RAM related. Bought a Corsair 16GB kit a couple of hours ago and get the same result with either stick in any slot
Looks like it. Going to order the cheapest AM4 board available then RMA whatever is deadCPU or mobo then :/
At 44mm2 with the L3 it seems pretty small already and you have to wonder if it would be worth removing it and reworking inter-core communication through L2 and I'd have thought the large L3 ought to be useful for an APU with higher demands on memory controller. Kaveri on FM2+ came with 4MB L2 - which I recall L2 takes up more space on a MB per mm2 basis than L3 (not sure on the exact space difference per MB) and lower end quad core models launched under £100 according to pricespy (~£70 for the A8-7600 https://pricespy.co.uk/product.php?pu=2755150).
Just some hypothetical messing around with quick back of the envelope calc's for Zen total cache options for APU (although in no way of taking into account the many implications of different L2/L3 arrangements)
L2 1.5 mm2 for 512KB-> 3 mm2/MB
L3 16 mm2 for 8MB -> 2 mm2/MB
Options for 4C CCX
1.) 512K L2 x4 + 8MB L3 = 10MB on-die cache = 22 mm2/CCX
2.) 512K L2 x4 + 4MB L3 = 6MB on-die cache = 14 mm2/CCX
Without L3 and L2 is shared:
3.) 1MB L2 x4 + NO L3 = 4MB on-die cache = 12 mm2/CCX
4.) 1.5MB L2 x4 + NO L3 = 6MB on-die cache = 18 mm2/CCX
5.) 2MB L2 x4 + NO L3 = 8MB on-die cache = 24 mm2/CCX
I could see them leaving the CCX cache sizes as is for the APU or at least retaining a smaller L3 cache. In comparison to the existing CCX in option 1, option 3 seems a no go as you save 45% the die area dedicated to cache to lose 60% cache capacity (and a massive reduction in dedicated cache p/core, accessible cache p/core and contention with 3 other cores for access to fetching any data not in L1). And looking at option 4 vs 1 you increase area dedicated for cache by 22% and gain 66% cache size (and gain much more p/core dedicated cache with no contention to search and fetch from the next level of cache with a private L2).
They could reduce the L3 to 6MB /4MB or less but I would have thought that can't come without some adverse effect on CPU performance especially with the igp contending for ram access and potentially using a lot of bandwidth. But then again the typical use of these chips isn't necessarily going to be that demanding.
We'll find out when we found out I suppose. Ultimately we are talking about saving a cpl of mm2 (~10 max maybe?) on a chip that I guess wont be smaller than 150mm2 (4C die variant). Could make much more sense for a 2C die but the area saving is halved so it would probably be for power reasons.
States private vid for me Cat .
Second one works though
Is it worth sticking extra 16Gb of memory for Ryzne 5, I have spare 16gb kit lying around. Is so what would be the speed that can be achieved with 4 sticks?
). I'm thinking B350 as it's a bit cheaper, although would get the X370 version if it's much better.Apologies if this has no doubt been answered before, but is there much difference between B350 and X370 chipsets? I'm looking to get a Asrock ITX board. It's going to be used with a 1700 and probably be left at stock or maybe a very mild overclock (it's going in my non gaming PC, so already massively overkill). I'm thinking B350 as it's a bit cheaper, although would get the X370 version if it's much better.
