He said he has Fibre with Plusnet so no spare should be needed.Isn't an FTTC activation allocating a spare port to the new provider and then an Openreach tech doing the jumpering in the cabinet, so it requires a spare?
A lot of the time when they run a check they look for an empty port on the cabinet rather than checking if you have fibre. I know when we (sky) check by telephone number we pick up the existing fibre connection. I can't speak for other providers though.
MissChief do you know why when I try the Sky checker, it says I can only get Sky Fibre and not Max (formerly Pro)? I used to have Fibre Pro last year for 2 years.
I already have an existing Fibre 65/18 line with Plusnet currently. Initially I thought Sky's own network is classed as LLU almost, so maybe their kit is full. But then thought well if that's true why can I get the 40/10 package still?
I tried live chat and the bloke said I can order Pro but not Max. Last I heard Max replaced Pro? But he said I can order 'Pro' but I had to ring up... Am I missing something here?
From what 'BT Chat' said to me I think the reason BT wont supply fibre (want to give me Faster Broadband instead), is due to the speed estimate for my line being to low and the distance from the cabinet.
This is the dslchecker results:
If you can order Pro then there shouldn't be a reason why you can't order Max. Pro essentially IS Max, just without discounts and a 12m contract instead. What does http://dslchecker.bt.com say for your 'clean' Fibre speeds?
I think it's because of the speed estimates being so low that Max won't really be worth it in some companies eyes.
... Throwing custom away! Especially as I used to be on Fibre Pro before.
.Hi all,
Just had my BT upgraded to Infinity 2 (from Unlimited Broadband at 7mb).
How long does it usually take for the downstream to get up to speed? I appreciate I've only had it activated for a few hours, it's currently at 20mb according to Speedtest, out of the quoted 72mb. I assume I should just be waiting a few days to see how it goes?
It should be near enough max from the go. How are you testing?
