Either is fine. Same name on either (look for the paintball picture on steam)Folks, how do I add you to my friends list? Steam or Oculus?
Played the first 20 mins. Looks stunning. Back at it tomorrow for a longer shot.
Grrrr c`mon hurry upYour OVERCLOCKERS order will be delivered today between 13:30-14:30
Edit:
Paul is currently making delivery number 7, you are delivery number 39.
Paul is approximately 3 hours 30 minutes away from you.
C`mon Paul,put your foot down![]()
Welcome to the longest day of your yearGot mine!
I'm at work![]()
Wait until you try robo recallMy Optic PC & Rift bundle arrived at lunch time. I've just set it all up and been through the tutorial with the little robot chap... all I can say is WOW!
VR is a game changer this is the first genuine new gaming experience I've had since Half Life 2 with the physics and the mavity gun!
The unboxing experience was really great too. This much tech for £399 is insane value.
Now I need to find time to play some games and not just the tutorial![]()
That's really odd. Do you have the wheel plugged into any USB ports that are sharing the same USB controller that any of your Rift hardware is plugged into? It's all I can think of - using the Rift shouldn't have any effect with your existing peripherals, so maybe it's a USB bandwidth problem.Anybody here using there Rift with assetto corsa and a thrustmaster t300 wheel ? its just i cant get the wheel to work when using the Rift
Any tips welcome thanks![]()
