Oculus Rift
Folks, how do I add you to my friends list? Steam or Oculus?
Feel free to add me as well :)
Steam: RockSteddie
Home: R0cksteddie (the 0 is a zero)
Due to having a 2.5 year old to contend with I don't generally get a chance to play until later in the evening though, normally from 9:30pm (if I can keep my eyes open!).
Cheers guys who gave their names, I will do the same later also!
Isnt there a VR names DB sticky? We should do one really.
It was very funny when I tried rec room, (haven't played it yet properly).
Wasn't sure if my mic was working...
So I looked up at one guy and said.. "Can you hear me?"
"Yep loud and clear" and hes waving at me also.
Very cool :)
Cant help but wonder where this will all go in 20-30 years time.... (Ready Player One...)...
Your OVERCLOCKERS order will be delivered today between 13:30-14:30
Grrrr c`mon hurry up :D
Edit:
Paul is currently making delivery number 7, you are delivery number 39.
Paul is approximately 3 hours 30 minutes away from you.
C`mon Paul,put your foot down :p:D:D:D
Anybody here using there Rift with assetto corsa and a thrustmaster t300 wheel ? its just i cant get the wheel to work when using the Rift :confused:
Any tips welcome thanks :)
My Optic PC & Rift bundle arrived at lunch time. I've just set it all up and been through the tutorial with the little robot chap... all I can say is WOW! :D
VR is a game changer this is the first genuine new gaming experience I've had since Half Life 2 with the physics and the gravity gun!
The unboxing experience was really great too. This much tech for £399 is insane value.
Now I need to find time to play some games and not just the tutorial :p
Wait until you try robo recall ;)
That's really odd. Do you have the wheel plugged into any USB ports that are sharing the same USB controller that any of your Rift hardware is plugged into? It's all I can think of - using the Rift shouldn't have any effect with your existing peripherals, so maybe it's a USB bandwidth problem.
Set-up went A OK
No problems at all(except could not get controller to register :(.....Put battery in right way round Idiot :o )
Watched/played the into/demo with the little robot
tried google earth nice!
A few others then Mission Isis.Loved the scenery :D
Then i tried moving :eek::eek::o Not good started to feel queasy in seconds
First impressions
Face foam gets me a bit warm/hot
I probably need to sort out some glasses/lenses as image was not as sharp as I would like(will CAREFULLY TRY MY SPECS first)
Don`t have a large enough area so mostly will have to use standing in one spot or seated
End of my first hour....Thumbs up:D
