- 30 Nov 2011
If it required a 1000W psu the recommendation would be 1500W.
Recommended doesn't mean that's what it uses, it means that's what they're happy to say will cover the card and a high wattage budget for cpu/mobo/drives/fans etc and extra wattage on top just to be sure.
A decent quad core with a decent card can easily peak below 400W, is the recommended psu 400W? No, more like 600W+
Yes but for even for a 400w gpu a 750w recomended should be plenty, recommending 1000w for a card thats supposed to be 300/350 seems massively over the top. Even SLI setups dont get 1000w recommended.
