Caporegime
- 9 Nov 2009
- Planet Earth
360w is low power mode? damn.
Actually they were for compute work, mining was just one of the compute buzzwords they stuck on the slide. In order for that to be of use somebody would have to make a new coin who's miner took advantage of them, and being easy to mine isn't exactly something that sees a coins value rise.
Wrong - have you seen results for the Vega56 in low power mode?? Nope,and in the normal power mode they used at the wall power was 290W,even with an overclock to the RAM and the new driver.
You know very well Vega64 dropped 200W in power just in low power mode with a decrease in gaming performance of 10% and you fully know people have reduced Polaris power consumption massively whilst maintaining mining performance.
Or do you seriously believe the RX580 cards being used for mining consume close to a stock Vega56??
Edit!!
Even on this very forum loads of people were discussing mining and said dropping core clocks had very little effect on mining performance.
The fact of the matter,is that with one experimental driver release mining performance has gone up 20% so what do you think is going to happen as more tweaks and drivers come out??
This is why the miners are buying them.
It will also pretty much kill Vega for gamers as prices will probably go up now.
