What have you done to your car today?
Interesting! All I see is the photobucket placeholder image. They controversially started charging an obscene amount for third party hosting. All the photobucket images on the net are broken :(
Wheels look likely Phil, shame the Rainsports don't have a rim protection. Your cars are always clean and tidy :)
yup! photobucket is rubbish avoid at all costs, has been rubbish for years but now it turned into a nazibucket..
I just stick to my own host so I have full control over it :)
Fitted my new intake today on the ST had a nightmare undoing the screws of the original intake cover. They where so rusted as soon I put the head in the fell apart.
Other than that everything went perfectly. Need to take out for a bit of a longer drive but seems good from the 10 minutes I took it out.
Service and MOT day, just the one advisory...
I'm intrigued to know what the donkey thing is! :D
With greasing gear link rods is there a specific type of grease to use? I need to replace mine and have some copper grease, will this be ok?
The tutorial I was viewing is this one:
[edit] NVM, found this great thing called google...
Took apart my dash.
y4mDCYyazzTP3LtazEMTD76g10Rb7CpmjXqmZRswHFtVeVrzgcSod9ru6rid6XkRAvbvcVB_4Zp0Rs9OnN0ZoKGjMh1TwUM9kN0NPeKwcN9pfwFNWXU5Vh4u56APSpgz9Y2X7n28iG1hKRZzU2FQQbhhOY_je1p8bMkbCGI38obsiZXoZPKynwYs9BLXxSnE34cLmctBib4-Bz_LEg1ZXbv-g
The put it back together again:
y4mMdOHw8yzK8uTbcAMBFj9WrQ6e9antOK_l76Pc1aFC8rp4MIubAArOJG_BLPDT8ZZSFMnY7VLEcDp5-Gp8kGgUhfhMtBR2D9ygzK9MDrvaGJHrCL285rElnZwUg3jX8Nup8-JT2Svv8jW3J42WVkBGhvh-ZMiOMIr5F2UzqXCosKriNXCA92le8S7nBkZrvbZw7LlTA16JzrbqUFZPNqKmQ
For some reason I can't work out, my odometer stopped counting up but I have a couple of spare sets of instrument clusters so I tested one from a lower spec car (hence the clock and no rev counter in first pic) then ripped them both apart and created one fully working set from both.
y4mjVqAx3PUJVzuZXO6WRBukTvULd3cDR8ZEZ32E1xVchiWUo41rJxXI3M0MxSoS1BGFB447WOiyWKQPney2lyNPDv_CH1BlSStPYJWjfICzK-HW5rfxoCB80ylFsDb6tn25H4RgFjDXtMq0pCi72YHVjwsH8ALXnEG9Yk9E7PY8JvYKmXqFBL7p9zJEY_ofVvl31Qwf4Hd_ew9AQRZCj892Q
I also polished my exhaust tips, because stainless needs to be shiny...I really can't be doing with dirty tips but also, sod cleaning the whole stainless system, need a lift for that.
y4m6WtCpO5ztsZy8pvE8cWtkjPwK8y8TSPzuTzumoeiTED-_CX5gYXHqRyydq6rsGDYzZrfc3vXxSSzZPhrDeMLLw239XGvkwHdw28_6LpbJYUbRtJ7vpmZSDZ47uK7v0V6Kuz4pjcI-qKgZnOE_c2I0cIs2hyoSE4vBE8oK66gqiizfavD74LI0duH2wdDmyYXgMK70i4Qm4gbRAFYdmEeVQ
Fine wire wool is great for exhaust tips :)
Only bought the system in May and have covered something like 1000 miles with it so it's fairly clean and tidy anyway and being stainless for ~80% of the system it should last a good while. It just gets water spots / marks on the tips so some soft cloth + autosol works well. Ideally I'd clean, polish and protect the whole system but as I say, I'd need it on a lift for that really...sod doing that on my back with it on stands.
Tried to find a decent place around here to get it washed. Don't have the capabilities where I now live so unfortunately I'm going to have to pay someone to do it :( :(
May take it to have it done tomorrow or monday; either way I'll polish the exhaust tips tomorrow :)
Machine polished her, followed by a hard wax and a good buffing with machine
Protected for hopefully one more year (i use liquid waxes on monthly washes)
