Connect up the SSD - power and SATA cable to SATA 0 input.
SHoudln't be - navigating with keyboard is easy enough.Mouse is wireless.....will this be a problem at this point?
SATA 0 is fine.
Connect mouse if not done so already
Then press case power (check all switched on) and press 'delete'on post.
Once in load 'optimised defaults' - in the 'Save and Exit' section.
Then save and exit
Then boot to BIOS again - and switch off.
POst back...
EDIT: Making kids lunch etc... so don't worry if delayed reply (I will let you know when i'm going out.)
@PlecOK, i have about 30-60 minutes tops - then going out.
But we should get you operational testing and then additional setup when i get back.
Looks promising so far.
Great - expected to have to walk you through it.ok, windows installed
done![]()
i just chose expess install (was recommeneded)?
- No matter - it would have taken a lot longer doing custom route.Also havent connected to the internet yet
Could you clarify what you'e done, please.
Bleah!- No matter - it would have taken a lot longer doing custom route.
Next job...
