Hahaha! I love the 2 page blow up of back and forthing, deffo made my morning
- Apologies but I can't remember everything that was said so i won't address every point (even though I could just go and re-read but I have work to do...)
1700 vs 7700K... pretty even BUT... look at the lighter blue 7700K line and compare it with the Ryzen lines, the later is clearly smoother. even the 1600X is smoother than the 7700K.
So based on the benchmarks you've posted, I can surmise that an 8 core CPU is better than a 4 core CPU ... which I already knew this and doesn't really help with my decision ;D - 4 core CPUs are off the table entirely, i'd only consider the upcoming 6 core 8700K however after everything that's said, I think i'd be better off leaving that one off the table also!
The gist of your arguments are all based on content creation/highly threaded apps first > gaming second. - which is cool, I get why you recommend the Ryzen over any 4 core intel. - However i'd be more inclined to go with Threadripper for this use case, 16 cores are better than 8 right!?
also I appreciate your benchmarks are meant to highlight a difference in cpu restrained workloads, but I'd never ever game in 1080p on my machine ... I run 3440x1440 and am even considering ditching my lovely 21:9 ultrawide for a 4k 16:9 HDR model
(i know! i hits me in the feels just saying it!)
For the record, i wouldn't ever buy a 4 core Intel now. except maybe the 7740x for pure Mhz.
From what I've read, the gist of your arguments are mostly based on Gaming First > content creation/high threaded apps second. - which is actually more the angle I was going with in the first place, thus your recommendation of the 7900X despite my initial apprehension due to the heat issue is very interesting.
You actually have an i9-7900X, so you'd be the best person to ask.. have you tried overclocking it? what were the best clocks you managed to achieve? and what temperatures did it pump out... based on your sig can I assume you have a custom watercooling system? and I believe you said that your chip was not delidded... so yeah, info please!
Sorry to distract from all the bickering, but I would like to suggest a simple solution for you. Give your budget seems to be ambiguous, yet pretty high, and you don't seem to mind setting up and configuring your own hardware, why not have a bit of an experiment to see where it gets you?
Pick up a Ryzen 7 1700, and a cheap X370 board for about £400 all in, if you need to get some RAM that will be compatible with this and possibly an Intel system moving forward, however I would imagine what you have in the 6700K system will do you for now, so no added costs. Setup the new board, and CPU with your gear and take it for a spin, see how it feels, do your own tests, and benchmarks, get a feel for it, should you hate it, or the performance in not there that you expected, then you can probably sell it on losing no more than £50-70 but you'll have first hand experience. Also it allows you to spend time waiting for Coffee Lake (Oct/Nov release) gathering real data, and comparing it to the reviews etc, unless your time is super precious and you can't afford to waste it then this route will give you the best answer you will ever get.
Which ever option you chose to take, I am sure lots of people will tell you it was wrong, or stupid.
haha no doubt my decision will end up being the wrong one! ;D - thanks for the suggestion, though I can't particularly be bothered to setup a whole ryzen machine just for testing purposes and sell it on... plus I'm thinking i'd rather just grab Threadripper if i'm going to go AMD.
I would be inclined to get an 1800X tbh. They are getting extremely cheap for the performance they offer and enable you capture at the same time. Although, have you considered a dedicated capture card?
Yes, if I were to get Ryzen the 1800X would be the chip i'd grab... or the 1700X as it apparently overclocks just as high as the 1800X without losing anything. - the dedicated capture card suggestion is interesting and something I hadn't considered... but I can still see myself upgrading to a HEDT system regardless.
I just felt if the OP wants to spend more time building their channel a dedicated PC would make more sense,and also give them a backup. Its why I suggested it. Even the dedicated capture card suggestion is a good one.
Thanks Cat, yes a dedicated PC that can do it all is what i'm really after, I'd rather avoid a 2nd streaming box.
Either way, good opinions from everyone here! - lets put a couple more 'rules' on the table:
no more 'mainstream' CPUs. - I'm after a HEDT system, so my choices are the Intel 7900X or Threadripper (I can't see the point of going lower than the 7900X as they start cutting PCIE lanes, and if I'm going to spend HEDT budgets, then I don't want compromises.)
Gaming First > Streaming/Video Creation Second. - This is my preferred 'use case', I'm running 2x nVidia GTX 1080 Ti's in SLI and a res of 3440x1440 so whatever CPU I choose will have to be able to run those cards at that res or higher without hiccups. - granted I have seen many benchmarks that seem to say that FPS ends up being the same on both CPU's (intel/amd) once you start getting into 4k resolution territory. - This is partly what makes the decision so hard! there's no clear winner here.
Budget is no option, assume I have £2000 to spend on a CPU+Mobo combo.
Thanks for all the suggestions and banter thus far ;D - Round 2, Fight!.
