The RX Vega 56 Owners Thread
28 Aug 2017
I have run the GPU-Z beta on my Vega 56 and it reports HBM2 (Samsung) memory. I understand from the GPU-Z author that this is reliable.
So, it seems that AMD is shipping Vega 56 with Samsung memory for now at least.
Poor Hynix
26 Aug 2010
Poor Hynix
Awesome:D
What Revision does the beta report on your card? Mine is C3 according to gpu-z 2.2.0 & the review one's appeared to be Rev 1. Wondering what the difference might be - if any.
19 Jul 2009
1w2Zr
http://imgur.com/a/1w2Zr
Has anyone else come across this at bootup?
I've also been unable to install drivers as it blue screens on me with a atikmdag.sys error which I can't for the life of me fix after spending all day on it!
At the moment I've got a very expensive red paperweight in my computer :(
18 May 2010
London
1w2Zr
Other than faulty, what is your PSU? Definitely seated properly and two separate power cables from PSU to GPU?
1 Aug 2006
took long enough but eventually.....
:edit: just doing coupe of benchmarks on r9 290 to see what the difference is for shts n giggles..
10 Mar 2004
Oxford
1w2Zr
Have you got an old x58 setup? I have the same problem when installing drivers.
Seems there may be an issue with older systems and the Vega cards
https://community.amd.com/thread/219437
After trying pretty much everything I'm returning the card and probably going for a 1070, which suddenly have gone up in price.
28 Aug 2017
Basic Fire Strike Graphics scores on the two Vega 56 BIOS in each Profile (+power limit) using top fan speed and everything else on stock.
LEFT BIOS:
Balanced Profile (+0%): 17576
Turbo Profile (+15%): 17866
Custom Profile (+50%): 18316
RIGHT BIOS:
Balanced Profile (+0%): 17220
Turbo Profile (+15%): 17631
Custom Profile (+50%): 17918
It would certainly seem that the left BIOS is producing higher performance. Judging by the higher temperatures and fan speeds, I would attribute this to the left BIOS running at a higher TDP in all three profiles. We see a similar pattern in the various Vega64 left/right BIOS. I can only hazard a guess at the actual TDP on the two BIOS in the absence of laboratory testing, but I would not be surprised with something like 200W right and 230W left.
So, if you really want to stick with a Vega 56 BIOS rather than flashing to a Vega 64, then at least you have a choice.
19 Jul 2009
That's disappointing if I've formatted my windows install for nothing that will be annoying. I'm running a Z68 chipset, would be interesting to see if others have successfully installed vega on similar?
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 01/09/2017, Make Reference Air, slunge, Link
Date 01/09/2017, Make Reference Air, Narrack, Link
Date 01/09/2017, Make Reference Air, Daiyus, Link
Date 31/08/2017, Make Reference Air, icey_haj, Link
Date 31/08/2017, Make Reference Air, Vince, Link
Date 31/08/2017, Make Reference Air, sideways14a, Link
Date 31/08/2017, Make Reference Air, MagicBoy, Link
Date 31/08/2017, Make Reference Air, Roob65, Link
Date 31/08/2017, Make Reference Air, sjones1404, Link
Date 29/08/2017, Make Reference Air, bells, Link
Date 29/08/2017, Make Reference Air, Sybra, Link
Date 29/08/2017, Make Reference Air, docsonic, Link
Date 29/08/2017, Make Reference Air, Disjunto, Link
Date 29/08/2017, Make Reference Air, old gamer, Link
Date 29/08/2017, Make Reference Air, FelixB, Link
Date 29/08/2017, Make Reference Air, megatron, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 56.
1 Aug 2006
Hmm, im finding the same thing - trying to install 17.8.2 and getting bluescreen every time.... im also z68.....
26 Aug 2010
I get revision C3 on both versions of GPU-Z.
Probably all the retail boards are C3 then if it makes any difference!
Very happy with my card anyway. I was worried about the ref cooler but it's fine with a bit of tweakage - currently got my card at 1030mv, +50 power target & 900 hbm:)
29 Aug 2017
I just got timespy GPU score: 6978 with stock bios. 2% boost on freq at 1080mv, 50% power limit, 915 memory on wattman.
1 Aug 2006
So.. tried 17.8.1 - same thing, literally no way to install the drivers with this card in - same error as everyone else and also tried 17.8.1
Also using gigabyte ga-z68xp-ud3... with 2500k, unbelievable AMD - guessing this is going back fairly shortly like others in that AMD thread above :(
Will try and install with my 290 - which i imagine will be fine, appears the minute you swap over to the vega it bluescreens anyway.
