The RX Vega 56 Owners Thread
well i had mine at 71c max but that was balls to the wall oc with 114% power limit 1680mhz core/1100mhz hbm with the fan as 3500-4900 rpm :p under water though its would be fine :D
Pretty good results, i had a feeling there was more under the hood. Did you use wattman for the fan profile I presume. If not what did you use.
Yeah I used Wattman for all the overclocking of Vega so far. I was going to play with it more this weekend but I had other things to do.
Anyone notice any sort of electrical coil whine type of sound off their cards?
I can hear a faint electrical coil whine type of sound when doing benchmarks. It's not irritating but something I do notice if I try to look for it. Thankfully nothing like those high pitched coil whine.
Jumper, what did you use to flash the 64 bios, ati flash or winflash, got a link to the bios I might give this a go
Atiflash. I don't know the exact version but it's on my pc I can look tomorrow
https://www.techpowerup.com/vgabios/194441/amd-rxvega64-8176-170719 the bios is here. The power limit will be Vega 64 power +50% so you have way more power even without power play tables. Hbm clock is moved to 945mhz stock and hbm voltage is also increased as well.
Great thanks
has anyone tried to fasten an aio to the 56 yet?
I was hoping the nzxt bracket would fit but looks like it wont, there's also a aio coming from alphacool
My setup with Vega 56 :D
Welcome and on TROH.:)
The Roll of Honour.
Date 03/09/2017, Make Reference Air, erazor51, Link
Date 03/09/2017, Make Reference Air, Angst, Link
Date 01/09/2017, Make Reference Air, solarp, Link
Date 01/09/2017, Make Reference Air, slunge, Link
Date 01/09/2017, Make Reference Air, Narrack, Link
Date 01/09/2017, Make Reference Air, Daiyus, Link
Date 31/08/2017, Make Reference Air, icey_haj, Link
Date 31/08/2017, Make Reference Air, Vince, Link
Date 31/08/2017, Make Reference Air, sideways14a, Link
Date 31/08/2017, Make Reference Air, MagicBoy, Link
Date 31/08/2017, Make Reference Air, Roob65, Link
Date 31/08/2017, Make Reference Air, sjones1404, Link
Date 29/08/2017, Make Reference Air, bells, Link
Date 29/08/2017, Make Reference Air, Sybra, Link
Date 29/08/2017, Make Reference Air, docsonic, Link
Date 29/08/2017, Make Reference Air, Disjunto, Link
Date 29/08/2017, Make Reference Air, old gamer, Link
Date 29/08/2017, Make Reference Air, FelixB, Link
Date 29/08/2017, Make Reference Air, megatron, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 56.
Did you have any issues when you flashed to the 64 bios? I don't remember exactly but I recall watching a 56 oc video on Gamers Nexus a while back and the guy said they couldn't flash to the 64 bios. I'll probably give it a go later this week when I get my waterblock on my card.
I think thats was just becuse it was only just out or even before the V64 was released.
