I give you that, it doesn't need all those buttons, especially as the screen is touch-screen.It's not bad, all those buttons in front of the Nav though...
agreed.Big fan of the new MX-5 RFs, looks really nice especially with the black plate.
With the 370Z interior, I'd take physical buttons any day over fumbling with a touchscreen whilst driving.
Thank you for the kind comments guys!loving the car
The rev matching is very subtle but good. Mostly just feel it when down shifting, don't really notice much when upshifting. The car is much quieter than I expected, I know it isn't a V8 but I would like a little more noise from it (I had a scooby which was fully decatted before, so maybe it is making my expectations rather unrealistic)agreed.
I love the 370z interior.
how do you find the rev match @Ace Modder ? very intrusive or do you like it?
Rev match is for downshifts only....
It gets quite aural high up in the revs, but you're right, quiet down low.
Well as the engine isn't bedded in yet (still only on 240miles total) I haven't given it the full beans experience yet.Rev match is for downshifts only....
Collected today
And it does match when upshifting too
Really? Rev matching on upshift? That's a new one on me..
The gearshift sensors monitor gear position as well as side-to-side shifter movement and are sensitive enough that you can hold down the clutch pedal and watch the revs jump precisely to the right rpm if you merely hint at moving the shift lever to a lower gear. But it’s not just for downshifts; SRM also sticks the engine speed at the targeted rpm during upshifts to prevent any lumpiness that might result from letting the revs drop too low. And if you push in the clutch pedal but don’t change gears, the engine will adjust to the proper revs before the clutch is fully reengaged.
@Gibbo that S button you pressed on my car on Friday, that's the button which enables/disables my rev matchingMy Mustang does this too, its called shift assist, when I tuned the car I had the tuner leave it enabled as I quite like it.![]()
Now no going over 35mph in your new toy
