All you girls with your fans. A real man just sweats. Buckets.
^I really need to get a big telly in my garage. They're just so expensive.
Looking at the KickR Snap myself too as the nights are drawing in here.
What other options would people recommend (direct drive any good for a similar budget?)
Come to the decision I need a plan B for winter - I'm generally ok to ride if it's just a bit wet but I don't fancy full on downpours or icy roads.
So took the plunge and ordered a Vortex, Ant+ dongle, USB extension cable. I used BC discount to get the Vortex for £270 delivered!
^ it is if it's aimless. Add in some structure and progressive goals and it gives you something to focus on other than just accumulating junk miles![]()
If you get on Zwift etc you may actually find you enjoy it, I know I did, otherwise turbo training is soul destroying
You should be fine tbh - it might not do 1080 but you'll be OK. I've run it on my iPhone the last 2 times, as my computer kept crashing.
