all max had to do was slow down and you can see him go into kimi
That's fair enough, Vettels trajectory was going to take him into the wall the way he was going.He does, but the apex wasn't at the end of the pit wall. He drove off the racing line.
He's race leader, doesn't he have the right to the apex?
I'm no expert though.
To be fair 3 in 1 into a corner never works. I think its an unfortunate racing incident.All Vettel had to do was not squeeze him into Kimi.
Vettel is beyond Max, it's Max hitting Kimi who then hits Vettel.No he doesn't, Verstappen is alongside, he has no right to the apex at all.
Watch something like Germany in 2014 when Massa decides the apex is his and ignores who is inside him then look at the 3-4 other pairs of cars going through the corner behind them. Those pairs alongside each other the car on the outside stays outside, those on the inside stay inside, all went through clean and no problem. Massa decides he wants the apex, flips his car and damages Magnussen.
Kimi/Vettel/Kvyat in Hungary 16, Kimi/Vettel/Max in Spa 16, Kimi/Bottas in Spain this year, Kimi/Vettel/Max here. What is the common factor, one idiot on the outside every time trying to push to the inside against a car fully alongside them.
Look at the bloody gap between Vettel's and Raikkonnen's front wings at the point of contact with Max. Their wings almost touch #NoHomo. Because vettel was squeezing max. Where was Max supposed to go? left, which he did but kimi was there too. Vettels faultVettel is beyond Max, it's Max hitting Kimi who then hits Vettel.
Did you know you can ease off the throttle coming into a corner or tap the brakes? Max was behind both Seb and Kimi that he hit into the side causing Kimi to go sideways and slide into VettelBecause vettel was squeezing max. Where was Max supposed to go? left, which he did but kimi was there too. Vettels fault
he did.Did you know you can ease off the throttle coming into a corner or tap the brakes?
I didnt see any easing off just a swerve into Kimi. Anyway stewards will see the data, wether Max lifted or was full throttlehe did.
go and look at the replay. he eased off a bit and went to the left where kimi was who also squeezed him trying to overtake him on the inside in a narrow track?
