Zwift gives you 25km free riding around the app and when I signed up I got another week free.I guess I'll get a trial in the box from Tacx - I'll definitely give it a whirl.
I also think it's personality based. @BennyC is clearly very goal focused and structured. I am clearly not as good at that
Bit concerned my laptop isn't going to cut the mustard - it's only an i5/integrated graphics/6gb ram jobbie.
Can anyone recommend any of the Zwift programs? I know there's a lot on there and they all seem fairly similar. Just looking for some structured training to increase power/fitness. Not fussed on whether it's 4 or 12 weeks. Eventually I'll sign up to TrainerRoad but wouldn't mind making some use of Zwift first
SNAP is good but also consider the Vortex smart, ideally both of them are so you can save money until you can get a PWM for the road AND a direct drive.What other options would people recommend (direct drive any good for a similar budget?)
Budget, look for a second hand Kurt Kinetic Road Machine or Rock n Roll. They're probably the best 'dumb' trainers, just don't consider the power module upgrades. InRide and the Smart Control are both garbage and a waste of money or time.Are there any decent budget trainer options for a 700 wheel? Maybe up to £150.
Needs to be reasonably quiet, and would need a new back tyre to swap for the gravel jobbie currently fitted. Not bothered by "smart" options but a remote adjustment for resistance would be nice.
Edit - reading that it might matter but my rear end is disk braked. 145MM hub width.
Good choice & deal!So took the plunge and ordered a Vortex, Ant+ dongle, USB extension cable. I used BC discount to get the Vortex for £270 delivered!
My old (10+ years) dual core C2D with 4gb ram ran it ok but it did have a dedicated gpu, an old 4670. It was't pretty but ran ok on lowest settings!Bit concerned my laptop isn't going to cut the mustard - it's only an i5/integrated graphics/6gb ram jobbie.
Push your budget a little and get the Tacx Flow (available from Decathlon & Halfords). It's an on wheel trainer with FE-C and Smart. Pretty much the cheapest smart trainer you can get! Don't forget BC discount either!
Surf around local Facebook groups for a dedicated rear wheel if that's also what you mean? Or ask your local LBS. You can get a new one for like £50-60. You can use old tyres until you can afford a dedicated trainer tyre, if your budget is £150 all in then you need to look at second hand trainers.
The Bluematic is not a FE-C/Smart trainer, it's what's known as a 'dumb' trainer. It'll not give you a power output, programs like Zwift/Trainer Road only able to estimate/calculate your power from Cadence & wheel speed. It has a manual 'resistance control' which means it cannot be controlled by computer (non FE-C) so things like Zwift can't increase resistance when you reach a climb.Wiggle are doing a Tacx Blue Matic, Tacx tyre and Tacx front wheel riser for a smidgen under 130 at the moment. Not sure if that's something worth looking at. The Blue Matic doesn't get bad reviews from what I've seen.
Different frame manufacturers see it differently, it's worth checking. Think some like Trek specifically cover it, some kinda do (don't say no to claims) while others when pushed will not want to cover warranties if damage happens.Found this regarding bike warranty being valid or not on a trainer, not sure if it's been discussed
http://road.cc/content/feature/2166...l&utm_source=facebook.com&utm_campaign=buffer
Make sure you can try it out before you buy.
The advantage of using your own bike connected to a trainer is that it has flex and the experience mirrors that of being out in the real world. The Watt Bike type bikes experience is like putting a saddle on a brick wall and riding that.
If you want to get involved with Zwift/TR then a Smart & FE-C compatible trainer is almost compulsory these days. You can ride without but you miss 50% of the training & enjoyment!Not that fussed about smart options, not sure I'll get them in my budget anyway.
N+1? Or make use of an older bike you've otherwise neglected?rather than faffing about with turbos, and using existing bikes, was the main plus
It should do but you'll still have the 'prompt' on screen so you can change direction if you wish. If you 'join' on another rider then you'll load whichever course they've chosen. If you join a race/group ride/event and ride before it you'll be following the course of the race chosen, but can change direction etc. When the ride starts then you'll be 'locked' into whichever course is set for it and unable to change direction until you finish.Zwift route question.
When I select a course in Zwift to ride does it automatically make you follow the correct path to stay on course?
I set up my Neo trainer today. The only slight issue I have is the gear indexing is slightly off so I need to spend a little time sorting that.
I'm running Zwift through an iPad Pro with an Apple HDMI lead to pass to the TV and have the iPhone on the bike running Zwift remote. Each fan is remote control (on/off) so I can warm up and then switch them on when needed without having to get off the bike
I ca never get my index perfect on the Neo when swapping from the road wheel which is spot on. Guess it's due to the spacer and hub etc but it's a pain.
