Think I win the prize for worst water cooling project ever!
I look through these pages and am blow away by the creativity and dedication people have put into their set ups. Clean lines, perfect bends beautiful lighting.........Isn't it about time we just see some turd!
well you're in luck! just keep scrolling.
So one morning a guy from work brings in 3 massive sheets of pink acrylic he saw a builder throwing into a skip. I asked What he plans to do with it? He replied "I dunno"
2 years later the stuff is still sitting at the back of the work shop collecting dust doing nothing. "if only I could use it for something, I mean it is a pretty fetching colour"
So I started by cutting some strips of acrylic then heating and bending them round some MDF.
I made 2 of these parts and cut them to lengh
Next I waited 2 weeks for a G1/4 tap to arrive from China, I'm not willing to pay the extra pound to get one from the UK, which came from China!
Then I acrylic welded the two halves together and set out the various ports on the back
Drilled and tapped the holes and cut the shape on the bandsaw.
Next I welded the back on and added some deflectors, I dont know why I added them but my other reservoir has then so why not, I mean they do nothing other than look trash and help to send micro bubbles back round the loop!
And here it is done. The ugliest, worst ever made pink reservoir.
While I was at it I also made a base plate for the bottom of the PC case. I've seen ones other people have made and they look fantastic....Mine on the other hand just looks like Katy prices washing up board.
I removed half the loop. I set the draining bored in place and fitted the compression fittings.
Added the pumps and drain lines to the res. SC600 pumps from China if any ones interested. they move a surprising amount of water and are quieter than my old EK 4.0 pump. How long they will last who knows.
Hard line tubing is so last year so I'm reusing all my old flexi tube fittings and going back to the 00's
Look at these bends pretty tight eh?
With every thing buttoned down I set out filling the loops up and leak testing. I also went with the worst 2 colours I could think of just to give the loop that je ne sais quoi.
And Finally the moment you've all been waiting for. The big reveal.
Voila!
Rip me all you can
this project was more about learning to work with acrylic than any thing else and seeing as the total cost was about a tenner I'm not fussed. this system will soon be broken down as the upgrade bug has bitten.
Hopefully you got a laugh out of all this, I did
