It's the sweet spot if you need 14 cores.
Have they arrived?
They have recently come in stock so hopefully, will be with me tomorrow![]()
Just placed my order, I will update post once arrived for the TROH.
Nice one mate
Stunning board, extremely happy with mine. Been at work past 2 nights so not had much time to play around with it yet.
But will get a pic up Monday for TROH when I'm off work.
I'm still mulling over the CPU choices at the moment, as I am trying to see what the temp differences are between the 7900 and 7920X with and without deliding and also how far they can be pushed.
My 7900x does get hot and will do 4.8ghz at under 1.25v. I suspect I could get 5ghz under 1.3v but even my custom loop won't keep it cold enough.
Even at 4.8ghz it's over 90c under heavy stress.
Been making a delid tool the past two days (should be finished tonight hopefully) as no derbauer tool stock until mid of October by the earliest.
That's really interesting thank you, will you be testing the delidding over the weekend then? As Id be interesting to know how your temps are effect before and after a de-lid. Also was your CPU a Retail or OEM chip?
I've been thinking about the 7920X because the die is a little bit bigger than 7900X, so I guess in theory it may run a little cooler due to more surface area but just looking at all the info at the moment.
Your making a delid tool. Make it well. One mm too far your losing memory channels as smd's get ragged off.My 7900x does get hot and will do 4.8ghz at under 1.25v. I suspect I could get 5ghz under 1.3v but even my custom loop won't keep it cold enough.
Why do you even want to run prolonged stress tests just use the pc normally.
