Caporegime
- 18 Sep 2009
- Dormanstown.
Got to love no MGPU scaling lol.
I think it will be found that the reason the 1080ti pulled ahead in 4K has more to do with memory bandwith & capacity than anything else.
In terms of bandwidth it depends on what card you get and what overclock has been applied by the manufacturer, at stock/OEM there about the same at 484 Gb/s.Nah mate, The ti has an edge in bandwidth and has more memory. That being said, the degree to which the ti pulled away from the 64 was not massive either. Things are very different between 1440 & 3840.
Very interesting, showing more games where VEGA is doing better than 1080Ti
It's not true. The games are broken.Interesting, I think Vega will age extremely well. Can't wait to see Wolfenstein II: The New Colossus benchmarks when its out.
Highly doubt that is the case. Youtubers main loyalty is with views and whatever can generate it, negative or positive doesn't matter.Mmmmmm Its been a good couple days since its Forza 7 Release and no big YouTubers showing its Performance!! Mmmmmm Dont want to show Nvidia in Bad limelight??
I suspect they are busy benchmarking the full game rather than relying on unverified results from a demo....Mmmmmm Its been a good couple days since its Forza 7 Release and no big YouTubers showing its Performance!! Mmmmmm Dont want to show Nvidia in Bad limelight??
The engine really seems broken.Highly doubt that is the case. Youtubers main loyalty is with views and whatever can generate it, negative or positive doesn't matter.
on a side note, i tried the forza demo on the windows store(eeeww) and its so buggy on my 1080ti. a lot of the geometry is missing when running the built in benchmark which leads to cars driving on thin air instead of a textured road.
And for most people the 60FPS lock means there is much to performance testing anyway.
