Yeah looking back as long as people buying the reference cooler are aware that you've still had to tweak the hbm2 clock, power limit and voltages for Vega then I don't think there's a problem.
Totally agree
On the other side though the 1080 was at a similar advantage, (like you say) from the water cooling helping it boost higher, just without memory oc. In essence both gcards have more to untap, but the Vega I don't doubt has to more to tweak and more to unleash at the cost of heat/power draw but heyho, even from your current 1610-/+ clock it'd be nice to plot frequency gain vs fps scaling say if you're lucky to get 1750-1800 mhz. Then we could put the difference in ref vs custom cooling in perspective of value.
Hwbot shows a greater range of 1080's at firestrike 1080p scaling from 23k- 25k+. But regardless I have just stumbled onto your vega bios thread and that's going to keep me reading for a while
I agree I did not push the GTX 1080, so it did have some left in the tank. Currently I didn't believe I am pushing the VEGA fully either. I reckon I have done mild tweaks so far, biggest change is probably HBM clock/PowerLimit.
I will have a nose on HWBot. HWBot allows tessellation tweak, which improves AMD cards results a lot, no idea about nVidia as I have very low experience/knowledge of them. The other think I once stumbled on was on Fiji if I pushed HBM to a unstable level it would remove say the smoke in Graphics test 2, this would vastly bump FPS/score. On OCN an avid HWBot user with Fiji also noted this, some of the subs "we" both agreed were at the level they were because of this. So I would take some results with a pinch of salt.
Great info there thanks, I've followed the stilt for years in his examination of Kaveri and then Godaveri/ Carrizo etc. How different or advanced is Vega over Polaris in the registers and powerplay tables?
For example Polaris looks like this but with Avfs/ temperature, current load etc the voltage and frequency tables obviously ride as close to the p-state.
Here's two examples of my rx470, 0% power limit and 15% power limit at auto voltage and auto clocks,
Registers dumps is so small that it reveals little
. Even though Polaris had AVFS the PowerPlay table revision I believe was older version than VEGA (will have to check). It had pointers to create manually set VID, VEGA has none, the VDDC_Lookuptable differs.
On another note a run my tweaked VEGA setup in TimeSpy last night,
link. I believe AMD have shifted to more focus on DX12 driver improvement, combined test does not lag behind as in 3DM FS. Over my period of Fiji ownership 3DM FS so very minimal gains driver to driver (pretty much static), TimeSpy did see improvement, I'll have to fish out results.
However my tweaked setup failed playing SWBF, crashed with <5min or so
. It had last well for several runs of SP 4K/3DM tests and several hours of f@h. I had to bump DPM 7 from 1100 to 1112mV. Then no issues in ~1hrs usage.
This profile is showing signs that due to the increase of VID for DPM 7 GPU is increasing GPU clock max even though I did not change DPM6/7 MHz.
Tweak 2 (the one that failed SWBF).
DPM6: 1557MHz 1000mV
DPM7: 1652MHz 1100mV
HBM: 1100MHz 1050mV
PowerLimit: 65%
So max 1100mV / 1708MHz, average 1070mV/1657MHz.
Tweak 3
DPM7: 1652MHz 1112mV
HBM: 1100MHz 1000mV
PowerLimit: 65%
I lowered HBM mV to see if I would gain lowering of VDDC on lower end of "scale", it had no effect.
So max now 1113mV / 1716MHz, average 1087mV / 1668MHz.
