Wow! Did it make much difference? I always use something like this to clean my fretboard. It has a little brush thing on the top that rubs on the fretboard. Having said that, I've never let my gear get that dirty as I have to make up for my lack of skill by knowing about gear hah!
Back into the bass world, I'm buying a Spectracomp compressor pedal this weekend. They seem to be pretty good from the reviews and videos I've watch. Hopefully I'll be able to have a play with one in Andertons on Saturday to make sure I like it.
You can basically program the pedal with a huge range of settings, and they're multiband so you're not applying the compression to the entire sound, which I think is appealing. This is my first compressor so I'm not 100% sure though. Definitely worth checking out the video below anyway. Note the tone knob is apparently a little useless, but once you're dialed in then you shouldn't really be changing knobs on your pedalboard whilst on stage anyway.
I also found a Badass II bridge on the Talkbass forums, which hopefully the guy will ship to the UK, so we'll see! I've been looking for a decently priced one for years.
Yeah come up really nice, my acoustic needed a good clean and a new set of strings as I had not used it for a long while, so it was a lot dirtier than it normally would be.
Really pleased with the outcome the lemon oil makes, got the lemon oil from Holland and Barrett
