I had that problem when spending ridiculous amounts on mountain bikes and parts
I just saved her ass with some help I gave her at work, so used that as a time to drop it in, before I fully build it up and she thinks I've bought a whole new bike. Wish me luck :p
Don’t forget your streamers
Oh, they're on order. Don't you worry about that. The basket seems like a must, too. Imagine what I could fit in that?
Needed a dedicated laptop just for music production and running music software. Tonight I came home with a Dell Latitude E6530, i7 3740QM, 16 GB ram, backlit keys, 256 SSD, 15.6" 1920 x 1080 display, Nvidia NVS 5200M. Everything works beautifully and boots up in 18 seconds. It's pretty much like a new laptop. I'm out of touch with what's regarded as fast but all this for £250 seems pretty good! Only thing broken is cosmetic, part of the grill over the air vent on the side.
How the **** is that bike standing up, sorcery and black magic?
5 minutes staring at it and all i've got is photoshop :(
You need an assistant, just holding at the back wheel off camera and after he pull the hands away the bike will balance for about a second before falling over/grab it again.
Or this, at the right angle going away from camera, you won't see it touching the ground, even if you do, easy enough to remove in photoshop.
