Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Notice regarding image hosts and attachments. See here.
Competitor rules
FYI "2" Tb not 12 and GPUs used for 3D workloads like modeling can make use of the massive amount of available memory.
Real time video creation also benefits, did you not see the amd video editing real time 8k footage very nvidia? Let me tell you it was a one hose race.
HBCC isn't just for gaming FYI
And who in the right mind says no to anything that gives you the possibility to add more to a system?
It turned out that was not true. I looked at Matt config file and changed my file with both poolSize and r_shadowAtlasTileSize to see what happened with default 4096, 8192 and 16384. It was surprised ran and it worked on GTX 1070 after few attempts when it froze at press E to start game with both 8192 and 16384 by closed Edge browser with many tabs opened so I can enjoying same higher resolution graphics on 32GB DDR4 RAM as Matt. However I tried to take screenshots but all turned completed black so I took pictures with my Galaxy S6 instead.
4096
// This file is for local settings only and will not be cloud synchronized
configVersion 9
r_lightClassThreshold "3"
r_shadowsDistanceFadeMultiplier "2.5"
r_lightDistanceFadeMultiplier "2.5"
r_decalFilteringQuality "4"
r_decalLifetimeMultiplier "1.3"
r_decalDistanceFadeMultiplier "2"
r_clusteredDeferredRendering "1"
r_decalFadeCulling "0"
r_waterLodViewDistance "32"
r_waterInterleaveUpdates "0"
r_filmGrainRatio "4"
r_sharpening "4"
r_SSDOQuality "2"
r_particleFadeQualityMultiplier "2.5"
com_showConsumerPerfMetrics "2"
r_windowHeight "1080"
r_windowWidth "1920"
r_mode "19"
r_lodScaleDeviation "0"
r_swapInterval "0"
is_materialAniso "16"
is_poolSize "4096"
image_anisotropy "16"
r_userOptionSkipGPUCulling "0"
r_shadowAtlasTileSize "4096"
r_shadowAtlasHeight "16384"
r_shadowAtlasWidth "16384"
r_particlesLightAtlasHeight "4096"
r_particlesLightAtlasWidth "8192"
r_particlesLightAtlasQuality "3"
161 FPS, used 7233MB VRAM and 7160MB 3200MHZ DDR4 RAM
8192
configVersion 9
r_sharpening "4"
r_SSDOQuality "2"
r_mode "19"
r_swapInterval "0"
is_poolSize "8192"
r_shadowAtlasTileSize "8192"
125 FPS, used 7887MB VRAM and 10794MB 3200MHZ DDR4 RAM, surprised higher memory usage than at 4096 settings.
16384
configVersion 9
r_sharpening "4"
r_SSDOQuality "2"
r_mode "19"
r_swapInterval "0"
is_poolSize "16384"
r_shadowAtlasTileSize "16384"
75 FPS, used 7894MB VRAM and 19059MB 3200MHZ DDR4 RAM, WOW massive memory usage than at 8192 settings and used more than 16GB memory.
4096
configVersion 9
r_sharpening "4"
r_SSDOQuality "2"
r_mode "19"
r_swapInterval "0"
is_poolSize "4096"
8192
configVersion 9
r_sharpening "4"
r_SSDOQuality "2"
r_mode "19"
r_swapInterval "0"
is_poolSize "8192"
16384
configVersion 9
r_sharpening "4"
r_SSDOQuality "2"
r_mode "19"
r_swapInterval "0"
is_poolSize "16384"
Lol if you think HBCC is the same thing. Go and do your research for God sake.
Note AMDMatt VRAM not RAM, the reason you taking a big hit on FPS is because the game is now using out of Vram.
The performance drop of for a amd is much less and I sure @AMDMatt will show you this.
nVidia have "pascal unified memory", etc. which is essentially the same as HBCC though AFAIK not possible currently to leverage with games unless they happen to be programmed for it (which I don't believe any are).
nVidia GPUs can page to system memory fine though HBCC can help to avoid some bottlenecks that the more primitive swap system will encounter - technically if you are properly employing HBCC you are also out of VRAM and ultimately still at the mercy of the bandwidth of the PCI-e interconnect unless you have additional local memory on the GPU.
The difference here is AMD you can set the amount of Available Memory for the Vram buffer to use. And they is hardly any performance hit! Unlike on Nvidia see his screenshots above the performance hit is massive and that's because all he doing is doing what any GPU does without HBCC and going to the much slower system RAM
With AMD HBCC its the cache controller here that helps reduce the performance bottleneck.. It works kinda like a Hybrid hard-drive in away that also have a slower drive boosted by a SSD in Cache.
Take note here of my GPUs dedicated Memory! This will not change like this on Nvidia unless they add a cache controller onto the GPU.
Pascal unified memory can do exactly the same thing without any additional hardware (nVidia just haven't bothered with it outside of CUDA as largely in the realworld its not particularly useful compared to developers actually implementing resource streaming/tiling systems that are optimised for their game). HBCC does allow you to make better use of the bandwidth available between the GPU and non-local or slower local memory and the bandwidth of that storage itself but it only goes so far - you can still saturate it and see the exact same performance slowdowns as the old paging system.
I hear that, and understand that it can do the samething. What I mean is Nvidia "User" is maybe what I should say can not set there own available memory pool to be used has the Dedicated Memory. This needs to be set by Nvidia themselves? Each game or something?
Surly they must have some additional hardware chip on the GPU? otherwise we back to square one and slow memory transfer speed between the GPU and Memory.
Not seen a single performance hit from using HBCC on AMD so far. if anything I have gained performance Squad for example seems to play much better. It has an option to load all textures into memory before game start this seem to help HBCC. i.e Am using 9GB Vram
It's a very nice looking game in parts and have excellent effects. Highly recommend enabling the higher texture and shadow quality. 11Gb vram will be OK for 8k
This removes the lower res texture that sometimes can be seen.
