- 29 Dec 2009
Generic question, but it's about time I gave this a proper clean, any suggested products? Thanks!
You may need to use an icc profile if you don't already have one. The washed out look is not really a fault of a decent tn but rather lack of calibration.What settings are people currently using?? I have the A04 revision and it looks washed out compared to my U2515H. I've reduced the brightness which has helped. Is it a setting or a natural difference between tn and ips?
I have just bought this monitor also. It's my first leap to Gsync technology. Unfortunatly the colours are terrible. I have come from an IPS panel (a dell U2713HM) and it was far better. Is there any settings to tweak it to get as close to IPS as possible?
buy a calibrator.
pity you don't live in glasgow. i would have came and calibrated your monitor for you for £30.
i was thinking of selling this monitor and going back to IPS until i calibrated it using a proper calibration tool and software. not by using other peoples settings. using other peoples profiles and settings will never work. you could make the picture worse rather than better. people doing that have no idea how panels work.
Which calibrators would you recommend? I'd like a basic one to do monitors, TVs and laptops. Not necessarily professional grade calibration, but I just want to get the best out of the display rather than doing it by eye
Without a proper calibration it will never be perfect, but using other peoples settings I am very happy with mine.![]()
ICC profiles can be a bit hit and miss but a large number of these Dells are close enough out the box you can take other people's OSD settings maybe tweak RGB values slightly and get very good results that for most non-professional uses are close enough as makes no real difference.
i think it's madness people are paying up to £690 for this monitor. yet don't want to spend £100 on a calibrator to get it looking perfect.
like i said before i was thinking of selling the screen it was that bad until i got a calibrator and calibrated it properly. i copied other peoples settings and it's nowhere near the same thing.
Exactly. For my main use as a gaming monitor, it looks perfect to me and I have no complaints for how it looks. I can't justify paying to calibrate it when I am happy with how it looks.
i'm not a pro calibrator. also i believe tv's are a lot harder to do than pc screens and need to be done manually.
e.g. the colormunki display i have you attach to the pc screen run some software and it auto created the perfect profile an dthen applies it. you cannot do that with a tv.
best asking on avforums how guys on there calibrate their tv's
This seems a good summaryWhat's the point of stuff like the Spyder 5 Express etc?
http://cameratico.com/articles/datacolor-spyder-5-review/
Id go up a level.
