Managed to get my DH to 53 last night is 3 and a half hours so not bad for the first night. Should be on tonight if anyone is about.
I haven't played for years, but started a WD near the end of season 11 and found levelling a breeze. Started DH last night and even on Hard only i'm finding it's taking absolutely ages to kill anything ..... like usual Maghda bounty rush (think i did on Expert) and tool at least 10 minutes kiting and slowly killing adds. Is it just a case of plugging away till i get a lucky drop to boost my damage then I'll be away, or should I be approaching it totally differently to the WD?
As a second question - I usually play solo so though DH would be a good choice. If anyone has any other recommendations [Not WD again] for solo play (consider the gifts this season as well) let me know
Cheers
I started on Normal difficulty doing one bounty with randoms and then the rest where rifts which was also with randoms. When i hit 37 i joined my mates group and then changed to hard to level up to 53.
Im kinda new to seasons as well as only done S10 and S 11.
For leveling I would join public groups as this I find is much quicker in leveling than doing it solo.
Ah cheers for the reply will try some groups later. May swap to barb as well
The first character of a new Season starts from scratch. Any new ones after that benefit from earlier progress.Don't paragon points carry across to seasonal characters?
Oh man, I've got my Monk just two achievements away from my full-set and wings but I don't know what the hell I'm doing wrong here. For some reason I simply cannot kill Urzael on T4 for love nor money. I get into battle, get him to that first phase where he stuns you and taunts you but then BLAM he insta-kills me. In previous seasons and for bounties on other characters I can melt him no problem, but on the Monk I seem to be failing somewhat. The Exploding Palm/Seven Sided Strike build I'm using takes down bosses in seconds, but just not this boss.
Any tips?
