- 19 Oct 2006
Nice, thanks @Caged
@nightmare99
Personally, I found the W9970 to be able to hold a terribly unstable line fairly well, and permitted DLM to see a stable line (by not having the HH phone home and DC you every week) to let DLM slowly increase speeds back up. Also allowed the cabinet to switch me down to 3dB slowly and increased speed to maximum (currently at 4dB for full 79999 download speed; could never get this with the HH5a).
@thewanted
Was done by OR side (my cabinet is a Huawei, so it had it running the xdB settings since March or something, and is also compatible with the chipset in the W9970), but with the HH5a it refused to do so over 6 months despite the cabinet supporting it (since March) and the HH5a supposedly supporting it as well.
I've read you could try and force the xdB as well to a specified level on the W9970 (and likely other similar chipset devices), but it was beyond what I was prepared to do to get it due to needing to basically "overclock" the damn line (change setting, keep eye on errors, determine if to go up or down, etc), which I certainly wasn't bothered enough to try vs letting the cabinet do it's work automatically (eventually) instead.![]()
I'm on an ECI cabinet I believe so I think I'll be on 6dB for a long time to come.....grrrrrr. Really tempted to try the W9970 though, especially for that price.So its been 19 days and I've still not had G.INP turned back on after my move to Plusnet. Also got some interleaving on the line along with an unreasonable low IP profile.
Is it just a case of waiting and being patient you think? Or should I contact them?
Stats recorded 30 Oct 2017 16:49:26
DSLAM/MSAN type: BDCM:0xa48c / v0xa48c
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 0 hour 5 min 25 sec
Resyncs: 2 (since 30 Oct 2017 07:34:23)
Downstream Upstream
Line attenuation (dB): 10.5 0.0
Signal attenuation (dB): Not available on VDSL2
Connection speed (kbps): 79997 19999
SNR margin (dB): 5.3 15.4
Power (dBm): 13.3 -4.0
Interleave depth: 8 1
INP: 51.00 0
G.INP: Enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0113 0.0000
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 4.52 3.76
Stats recorded 18 Nov 2017 10:10:06
Status: Showtime
Uptime: 0 hour 3 min 24 sec
Resyncs: 0 (since 18 Nov 2017 10:09:47)
Downstream Upstream
Line attenuation (dB): 10.4 0.0
Connection speed (kbps): 65768 19999
SNR margin (dB): 6.3 15.4
Power (dBm): 13.5 -4.6
Interleave depth: 1287 1
INP: 3.00 0
G.INP: Not enabled Not enabled
RSCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
Can she use my old BT router as part of her network to provide a wired connection to her tv box?
It's mostly clients that need patching, or routers operating in bridge mode IIRC. For most home users I don't think router updates are relevant.Have they patched krack yet? Haven't received any update on my HH6.
mines gone from Build stage to connect! i know its like asking how longs a piece of string but how long did it take some of you to be live from connect stage?
cheers
Oh no mines just gone to accepting orders to, hope it won’t take that longMine's has been on accepting orders which I did 6 weeks ago and still no further forward!
