Thanks for the info @Steedie![]()
Forgot to say, it was £1999 for the Panasonic so a bit more expensive than the E7 with the deals on
Even better deal: apparently you don't even need to order a TV for the code to work!
First places I looked at was £1899Yeah, best I can find is £1949!
You *may* be able to claim the £500 cashback on that too![]()
This really put me off LG OLEDsI was about to buy the LG E7 today but after seeing the Panasonic TX55EZ952B side by side I was blown away and bought that instead
The LG is simply stunning but next to the Panasonic there are a few differences that just meant the Panasonic was the one for me
How? Quidco or TCB? Or something else?
I love to see how the Panasonic OLED handles this
Sony A1 on the left , LG C7 on the right
https://www.youtube.com/watch?v=CI0C8UTCtCg
but then the sony OLED looses loads of detail on bright scenes
Other retailers seem to be applying the cashback beforehand so the customer gets an up-front deal, with JL price-matching then you may be able to get it. Check hotdeals thread (Hughes), couple of guys on there have also got a JL price-match.
And then you also got the Dolby vision vs HDR10+ hassleYeah you can't win with either one unfortunately![]()
Just ordered mine with the free rear speaker kit! What a bargain - Voice- I owe you a pint. Great spot!
Sure;
https://www.hotukdeals.com/deals/lg-oled55e7n-149900-hughes-in-store-only-2830956
It seems to be the latest one for comments/experiences etc.
edit - Seems to be a little confusion around atm due to the unorthadox way that the cashback is being applied. Chancing a price match def seems to be the way to go!
If we could get the e7 for £1000/1100 then that would be a cracking deal![]()
Doubt the E7 will drop that low but would love to be proven wrong.
C7 for £1349 via Currys!
