- 25 Nov 2011
- The KOP
Ive sorted GTA V, when i was redoing the settings, i missed the Shadows, popped em back up to 'Very High', and the Extended Shadows appeared.![]()
How are you finding the upgrade over Furyx?
, i popped HWinfo64 on, went to the Sensors, came up about some Intel thing detected, that may put too much load on, and cause instability (had the CPU open in the left pane at the time), so said no to monitoring that, and that was it, no signal, card slowed down, red light went off on the power connector, restarted a couple of times, wouldn't have it, no single LED lit on the power connector, monitor no signal, so hard switched off, back on, and she fired back up ok, just had to do the old start Windows normally.
