- 17 Jun 2012
Ok so it does 4025mhz on all cores @ 1.41v when I set it manually with 3200 on the RAM. Will see how it goes.
Why do you want to overclock. 3.7 is awesomeScratch that, not stable, put it back to stock for now as when overclocked it doesn't seem to down clock with any sort of C/P states either. Although at stock I never see a core above 3.7 :S
Interesting thing this here Ryzen, not exactly an overclockers dream...
Nothing wrong with 3.7.. It's an great overclockon a 1600x? it should be boosting to 4.1 stock but I'm not seeing it.
Maybe I have to back off the RAM speed to get the CPU stable.
Base is 3.6, overclockers.co.uk charge £100 per 100Mhz overclock on binned processors..Ok maybe it's an in joke, but 3.7 is stock...
Spotted: Ryzen 3 1200 CPU with Eight Active CPU Cores Enabled http://www.guru3d.com/news-story/spotted-ryzen-3-1200-cpu-with-eight-active-cpu-cores-enabled.html
Six Core AMD Ryzen 5 1600X Processors With Eight Working Cores Spotted http://www.guru3d.com/news-story/si...cessors-with-eight-working-cores-spotted.html
? Wonder if it's from the same batch as the unlocked 6 cores. Mine seems to be from April even though I bought it around August so I got unlucky
.I knew about the 6 cores but the Ryzen 3 as well? Wonder if it's from the same batch as the unlocked 6 cores. Mine seems to be from April even though I bought it around August so I got unlucky
Have you tried to unlock yours? Even if you don't unlock it, 12 threads have to be pretty sufficient anyways![]()
It's a hardlock so no BIOS trick will unlock the extra cores.
It was a June batch if I remember correctly where they forgot to lock the extra cores, so those who managed to get a CPU from that batch pretty much got Ryzen 7 CPU for the price of a Ryzen 5.
Ryzen 2 Crazy Specs Leak - 12 Cores & 5.1GHz
To trade in my 3.9ghz 1600x for a 5ghz 12 core with 24 threads, Wouldn't that be nice.
I think that belongs in the just too good to be true category for something like that to appear next year.
In 2019 however with the move to a 7nm process I can see something with those spec appearing.
