The RX Vega 64 Owners Thread
Does the same for me on firefox or chrome at the pc or on my phone, i had this problem with the last driver release also, embarrassing that they can't even make there driver page work.... doesn't give confidence in the driver software really.
Because people writing driver software also do the website development and/or maintenance? Well, not quite, three entirely different areas of expertise.
Hey guys, been watching this thread for quite some time and finally got my vega. Sadly enough..
I am quite happy to see so many people getting one but i had so many issues with mine that is crazy.
I got a gigabyte vega 64 watercooled and right of the gate several apps would freeze the pc when getting details of the system, such as 3dmark.
It did run the games fine but to my shock there was maybe only a 20% performance increase when comparing with my 970?!? And thats with my 970 at much lower temps with a kraken g20 and an aio wirh 280 rad.
Wattman refused to save profile settings, i set turbo change tab and when go back to it its in balanced again.
Turn freesync off or on and it was mostly off. Sometimes out of the blue it would turn it off or on on ita own.
Core temps quite fine but fps on most games and benchmark scores were really not what i expected. About 15k score on firestrike 1080p default :/ maybe its my 4690k bottlenecking? Cant be as in neither benchmarks nor games does it ever go above 50% usage.
1 day after installing it im playing rainbow six siege after several hours the pc just turns off and refuses to power on after that. I place my gtx 970 back and it powers up fine again. Guess that vega just died after 1 day... To my amaze as well core never went above 60C but when i checked the actual card physically it was around the 80'sC.
Anyone else experienced any kind of similar oddities or i just got a bad card on the lottery?
Now gotta wait 15 days for replacement ans it just gor out of stock on ****** :(
Thanks and best of luck to any new vega owner :)
:(, had no problems here with my Sapphire.
Now gotta wait 15 days for replacement ans it just gor out of stock on amazon uk :(
Sorry to hear you have problems. It's so annoying when that happens.
Things to try,
Download DDU and go into safe mode and uninstall all AMD and Nvidia Drivers.
Then install the 17.11.1 drivers. I had issues with mine when installing the 17.11.2 drivers without installing the 17.11.1 drivers first.
did you try the other bios on the card? Maybe it's a faulty bios and just needs a reflash.
Oh wait, just after reading the rest of your post. It's completely dead now? Hope you can get a replacement quickly!!
No, obviously they are different teams, I was just mentioning it doesn't inspire confidence when downloading software for such an expensive tech item when faced with an error page for the driver.
While i remember, the 17.11.2 drivers seem to have a bug where when you set a custom setting and play a game, when you close the game and hover over the reset setting button on wattman the entire thing crashes.
Also when i set Hbcc to on, the screen goes black for a long time and when it returns it mentions something about no found driver installed for my hardware, please install the correct driver for my device, but in wattmatt it shows the hbcc is on.
anyone else have either of these issues?
Things to try,
No I think you are on to something there, maybe he was on the power saving bios which is why none of the settings were changing for him. For sanity @AngelofDeath69 try to switch to the other bios setting on your card and see if it works
17.11.2's were buggy for me, tried DDU and reinstalling etc, but they only worked properly after I installed the 17.11.1s first.
The left is normal, flicking to the right is the power saver.
Lol. WattMutt also just sprang to mind.
Wot! Wot's Watkins wottling on about Wattman?
Another couple of drivers like that and it'll be equal to the 1080 :D
It's going in the right direction and it took a few months and a few driver boosts to get Fiji up where it should have been from the start, I imagine it'll be the same for Vega..
