 - 14 Jun 2014
 - Dublin
I found loads, just pick a make like "Team" from the top drop down menu and it should appear. Unless it has all been sold already ...
Link? I don't see any RAM on the Black Friday deals page.
Damn prices went up even more now 8pack kit costs more on deal than when yhey came out ...
Am looking for a 32GB kit for my ROG CROSSHAIR VI HERO, as the kit I just bought(loved the style in black)
Team Group Xtreem "8Pack Edition" 32GB (4x8GB) DDR4 PC4-25600C14 3200MHz Quad Channel Kit - Black
MY-094-TG
Wont overclock on a ROG CROSSHAIR VI HERO, Stays at 2133.
Any recommends out there? same kind of style. Not keen on the RGB memory's.
What ram voltage have you set? Try 1.4V and set ram boot voltage also at 1.4V. It should then boot at frequencies above the base.
What bios version?
Mate what does this sayAre Gskill Flare good enough for Ryzen 2*** series? guru3d said that the 3400 was a good bet for new ryzen 470 boards. Can't see Flare on the OCUK site though. Am I missing it, am I blind?
Wrong thread.The Team stuff (Samsung B die) seems to work very well with Ryzen.
You can also get something like this:
https://www.overclockers.co.uk/team...4000mhz-dual-channel-kit-black-my-098-tg.html
And use much lower timings than the profile has at e.g. 3200MHz and who knows, you might even get it running faster, not mucn more money either - if they fit with your cooler.
Screenie of ~8.5hrs run of P95 v28.10B1 (8K 4096K 13GB). So by just swapping RAM over I needed to bump SOC/ProcODT a bit to gain same profile as F4-3200C14D-16GTZ.
