Heard that the resurgence in Win7 is due to China.Not sure how accurate the numbers are. A resurgence in win7 over the last month and Intel not topping the GPU charts.
Yup, Windows 7 is a lot easier to pirate and so the flood of new gaming systems being built in China for PUBG/etc mostly run it. This is why Windows 7 usage seems to be increasing on steam whereas in the wild it's decreasing.Heard that the resurgence in Win7 is due to China.
You have to remember that the Steam survey is quite flawed and also indicative only of gamers who use steam so won't reflect actual GPU sales (especially as Steam doesn't have any mining apps lol).I did some calculations based on revenue on the two companies and the split was more like 5/6 to 1 not 10 to 1.
considering some of us opt out of the survey to.Going by a mixture of other sites looks like Windows 10 uptake has eased off a bit since the fall update and the falling Windows 7 numbers slowed down a bit - some sites showing a slight swing back on Windows 7 but averaged over several sites the rate of change flatlined rather than the ever increasing rate over the last year or so.
It isn't all that flawed despite some people claiming that who then go on to demonstrate they have poor knowledge of how it works. It isn't the most accurate survey ever but the results are fairly representative of Steam users.
It doesn't seem to be picking up on RX Vega correctly at this point but that won't massively swing the numbers.
edit: my mistake
apparently results are pulled from a 12th of the user base by asking people to participate.Individuals opting out shouldn't skew the stats by any meaningful amount - it polls a cross section of the user base - the sample size should generally represent the whole within a margin of error.
I think it’s fair to say there will be a refresh come 2018 and that it will offer improvements.
To what extent is debatable but yes it looks like the hype train is being resserected (again!)
Any leaks on 12nm Vega?
Over 70% of people who answered the survey have something no faster than a GTX1060.
To put that in context a XBox One X probably has a faster GPU than most gaming systems on Steam!
Shame they didn't replace the cpu as well.
