Yeah its not too bad that, i think the max is 70 before the throttling kicks in
Is this the case for the air cooled version too?
I think the air cooleds about 85.
What are your settings for getting 1800mhz on the core tony turbo (certainly earned the name) as soon as i set 1800 in wattmatt or some such program and run a bench mark it crashes instantly...
P6 1600mhz @ 1100mv and P7 1825mhz @ 1230mv
HBM 1100mhz @ 950mv
PL+50%
1825mhz gave me between 1790mhz and 1805mhz when gaming. But here's the thing, don' know if you've seen my updates earlier. Since I've upgraded rig to 8700k and z370 from the z77 and 3770k, I can' get anywhere near 1800mhz. I'm now questioning whether those clocks were accurately reported. Every piece of software I ran (gpuz, Wattman, MSIAB and hwinfo64) showed when gaming or benching my card core was at 1800mhz. But I can't even get 1750mhz now stable even on 1250mv.
It' a bit weird.
Updated Firestrike to the latest, and gave it a run.
Not bad for a stock card, Graphics Score looks decent.
That's a ryzen problem. My threadripper 1920x scores worse than yours on combined but higher on physics.Beats my stock. Unsure how your combined knocks me for six when my physics is a lot higher than yours and my graphics isn't far off yours!
https://www.3dmark.com/fs/14351869
I wouldn't bother, i saw no gain at all in a few benches and games with higher than 50% power limit when i tried the 150% power limit reg tweak.
@gupsterg can probably point you in the right direction.
Thanks for the reply matt.
I only ask because i did my own testing and like i said, i can get 1750 core on the 64 air bios with this tweak and it performs faster than the Lc bios at the same clocks but with lower temps. Crazy but true i promise.
Problem is the reg file i used to use no longer works with the recent drivers.
Anynews on adrenalin ?
, please give link to VBIOS you use.Be careful, if you add 50% to a LC BIOS the TDP will exceed the cards rated inputs (could theoretically damage the mobo or PSU).
Is this true? Ive seen plenty of peeps on here and other forums that run 1250mv with +50% PL to break 1750mhz core. Not doubting you or anything, that does make total sense though.
In theory yes though that doesn't mean it will happen in practice. If you increase the power limit of a 264w TDP card by 50% that raises it to 396w, if the card only has power sources rated at a combined 375w (a pair of 8pin connectors rated at 150w each and a PCI-E slot rated at 75w) to draw it's power from that means allowing the card to run up to it's new power limit will exceed the spec on at least one of those sources.
I contacted OCUK support in regards to the release date of the ASUS Vega 64 STRIX. The customer service agent said the supplier has put the release date back to January!!
Ironically, switching it to game mode, which effectively makes it a 1600x (6c/12t) boosts the combined score considerably but doesn't halve the physics score.
https://www.3dmark.com/3dm/23414628
https://www.3dmark.com/3dm/23217365
Have you got an old firestrike score. You could check your graphics score before and after. If if it's higher before then your clocks were reporting fine as Graphics score doesn't appear to change much from Cpu to Cpu but obviously overall score would be up due to the Physics score on the 8700k.
The only old ones I have are messing around ones to be honest, and at 1752mhz. I never got round to doing 1800mhz ones as we moved house and knew I had the new hardware coming.
My lastest is here https://www.3dmark.com/fs/14348525
I'm sure when I was rocking the 1800mhz on a quick run to test stability of GPU not CPU combined, I hit a few points shy of 26k so who knows.
1692/1100 (holds 1650-1660 realtime)
G score; 25682
http://www.3dmark.com/fs/14344384
1712/1100 (holds 1670-1680)
G score; 25880
http://www.3dmark.com/fs/14355612
Very good G scores. Can you run something more demanding though like FS Ultra, Extreme orTimespy Extreme. Standard can throw up some odd results.1692/1100 (holds 1650-1660 realtime)
G score; 25682
G score; 25880
I tried simulating your settings and my card crashes instantly. I know silicon varies in voltage tolerance but I think you might need to apply more voltage to get yourself up into the p-state comfortably.I want me some of that![]()
Thanks Matt it is dialled in as i'm on stock bios on air so i'm limited to about 1680-1700 MHz real time.Very good G scores. Can you run something more demanding though like FS Ultra, Extreme orTimespy Extreme. Standard can throw up some odd results.
