20 newish games tested on the HP.
00:01 - Destiny 2
03:12 - Titanfall 2
05:32 - Rise of the Tomb Raider
08:09 - Microsoft Flight Simulator X Steam Edition (1080p)
10:51 - Project CARS
12:39 - The Elder Scrolls V: Skyrim
14:56 - Micro Machines World Series
16:56 - Redout
18:53 - The Crew
20:53 - Rainbow Six Siege
22:33 - Crysis 3
25:21 - Total War: Warhammer II
26:21 - Overwatch
29:56 - Battlefield 1 Multiplayer 64
32:40 - Fortnite
35:28 - Middle-earth: Shadow Of War
38:30 - Rocket League
40:55 - Dota 2
44:13 - Counter-strike: Global Offensive (CS:GO)
46:10 - Far Cry Primal
Another 9 tested.
00:01 - Wolfenstein II
02:46 - Pro Evolution Soccer 2018
05:36 - Mad Max
08:43 - Metal Gear Solid V
14:39 - TrackMania Turbo
15:49 - CoD: Infinite Warfare
18:23 - Overwatch
20:23 - Assasins Creed: Origins
22:33 - Far Cry Primal
Yet another 12 games tested.
00:01 - Watch Dogs 2
02:12 - Deus Ex: Mankind Divided (DirectX 11)
04:13 - X-Plane 11
08:23 - The Surge
10:28 - Team Fortress 2
12:09 - Sniper: Ghost Warrior 3
13:40 - Prey
16:09 - Mortal Kombat XL
19:18 - Killer Instinct
21:04 - Fallout 4
24:25 - The Witcher 3
32:29 - Ashes of the Singularity: Escalation (DirectX 12)
So 41 games tested in total. I am surprised the IGP can even run some of those titles. I am definitely interested to see how the Ryzen 7 Mobile and the Ryzen Mobile Gaming SKUs will performance when they are released.
With similar systems,with similar cooling,etc the AMD system was not much lower than the Intel system and the fact of the matter is Nvidia Optimus switches off the GPU if not under heavy GPU load. I should know as I have mates who have systems with Nvidia dGPUs where the thing switches off so battery life and power consumption is improved. This is not 2011,its 2017 dude!
Even look at the Intel system you post,how does it compare to other Intel systems with the same CPU,this is why you need to equate cooling for both. If the Intel system is throttling more it will post lower power consumption readings,etc.
The fact is the 2017 models of HP X360 are not massively different in battery life.
Plus also you seem to forget one thing - if the AMD CPU was consuming FAR more power,in the same chassis and with the same cooler as the Intel system,it would probably post lower overall CPU scores,but all indications say the system does not run massively hotter or throttles any more than the Intel system.
Likewise,the Intel system if producing less heat should boost much higher. There is no indication of any of this from any review I had a quick look at.
The fact of the matter,is that battery life is fine when metrics are similar - remember you are argueing over 2% to 10% when it comes to battery life,but the AMD system is faster with regards to CPU and GPU.
Both X360 systems have under 6 hours battery life and the screens are not bright enough so ultimately yes its a meh system.
In the end its a solid chip,and in the end I would argue a better rounded chip than the Core i5 8250U.
The thing is cost is on AMD's side - Intel can only really compete by bundling a lower end Nvidia dGPU which is less cost effective for OEMs.
