If id be on 50k+ would already ahve oneThe card, Nvidia, The price. Absolutely everything about it is pathetic.
Fastest is fastest like it.Only pathetic thing is AMD's Gpu range
Heat spreaders have become something of a status symbol over the years, to the point where all the decent spec memory has them, thus you can tell from their absence that it's slow and/or cheap RAM.Why would he need heat spreaders?
ECC helps with data integrity not performance, the high end stuff still uses heatspreaders.That's great, except these are likely ECC modules, too.
We were just mocking the fact the guy had spent so much on his system then cheaped out on slow RAM.Don't think you're thinking this through lol. I think you've just got a very warped perspective on the rig shown and how it is purpose built. It would be more odd if it did.
That's great, except these are likely ECC modules, too. Don't think you're thinking this through lol. I think you've just got a very warped perspective on the rig shown and how it is purpose built. It would be more odd if it did.
Nice round number lol. Doubt the CPU will make too much difference, although mesh on the 7980 may even hinder it a little bit in comparison to X99
I'm in disbelief you bought two, dude. Why lol
In fairness they only recently dropped the Geforce name from the Titans, they know full well that 99.99% of consumers still think of them as Geforce cards.
Correct. It's a sneaky way of operating. Presumed assumption.
I tried to cancel the second one when I found out there was no mGPU support but NVidia sent it anyway.
In the end I decided to put one in my 7980XE and the other in my 6950X systems.
There is something I do not understand about my 7980XE system -
Every GPU I put in there performs about 5% less well than my 6950X system clock for clock on the card.
When it comes to 2 way SLI in Firestrike the difference in graphics score is huge in favour of the 6950X. I have also noticed that Radox has the same problem with his 1080 Ti cards and a 7980XE.
If id be on 50k+ would already ahve oneFastest is fastest like it.
Only pathetic thing is AMD's Gpu range![]()
)Or maybe you would appreciate the value of money more.
If you have some real use for the card, fair enough, but spending 3K on a graphics card to play console ports is not a wise decission.
AMD are in a great price / performance spot when you include the monitor tech. Something they tried to educate people on at the launch of Vega.
(says me, with a 1080Ti FTW3)
C'mon Kaap, the podium beckonsThe Kingpin is dead, long live the King !!!!
I think you’ll find AMD tried a number of clever marketing tricks when they realised that Vega wasn’t all that.
It’s akin to Ferrari focusing on how well the car can be cleaned rather than it’s performance.
Well what use does freesync got when I'm using my PC for full scale VR with dedicated room for it ??![]()
)As i see it Money got NO VALUE. TIME is real Value !!! You can have 10 0000 00000 whatever milions off whatever courency,. Yet Time is real limit of what Youi can do with them ect.
And thats reason i dont chase money at all. And spend any money i got on random gifts for random ravers i meet at events. Sometimes see em once in life.
If i can make someone have Better time its worth more than anything from my point of view![]()
Intel's changes with mesh favour bandwidth for more workstation focused workloads, but sacrifices latency. Games suffer because of it. Overclocking the cache and memory should bridge the gap. Also multiple cards are likely still better optimised on X99
Has anyone had much success overclocking the cache?
As to overclocking the memory mine CPU can only handle around 3733mhz and the memory I have installed is good for over 3866mhz so not even running full speed.
C'mon Kaap, the podium beckons![]()
