Hi Hiijinx
Sorry, but I don't know anything about running Nord through a router if that's what you mean, I just downloaded the Nord software and
done the above in my previous post.
Try running something like ccleaner and these servers first and then try Netflix again.
American servers: # 707-710, 722-733, 868-875, 884-887,940-947, 952-963, 980-987, 1074-1153 1154-1193, 1196-1283.
English servers: # 15-20, 30-34, 36-41, 47-51, 53-101, 196-207, 228-239
Long shot (kick de bucket) it's your browsers geo location and ipv6 enabled.
https://ipleak.net give it a minute or so to finish and click on > Activate (may prompt an user permission on the browser) under > Geolocation detection
it should say " User denied the request for Geolocation."
Top of that test page " Your IP addresses " should say " No forwarded IP detected. If you are using a proxy, it's a transparent proxy.
IPv6 test not reachable."
All Ip numbers on ipleak page should be Nords.
If not , Firefox > about:config > media.peerconnection.enabled < disable
Opera > Settings > Show advanced settings > Privacy & security > WebRTC > Disable non-proxied UDP < tick
Other/more options
u block > settings > privacy > Prevent WebRTC from leaking local IP addresses < tick
WebRTC Network Limiter
https://chrome.google.com/webstore/detail/webrtc-network-limiter/npeicpdbkakmehahjeeohfdhnlpdklia
WebRTC Leak Prevent
https://addons.opera.com/en-gb/extensions/details/webrtc-leak-prevent/
Disable Ipv6
Run ccleaner and try ipleak test again and then Netflix.
Change computer clock time zone to to the country / server used if Netflix still doesn't work.
If Netflix do a free trial I can test Firefox and Opera with Nord for you if none of the above/my previous post works.
Other/more options
WebRTC Leak Prevent
Disable Ipv6
