https://forums.overclockers.co.uk/posts/31410122/CRU works setting the Freesync range to 30-75mhz
From earlier this thread; 30-75Hz.
Cheap and cheerful enough for me to be happy with the purchase, but my one outstanding question remains:
How do I turn the volume down on the monitor when connected to HDMI with 3.5mm out? Seems no way to, which is annoying when gaming with headphones!
just use the left/right buttons. don't click into any menui hope there is away to control volume via monitor but for now i will use my spare headphones which have inline volume control.
It does, but I had some intermittent issues with flickering so rolled it back a bit. Still trying to find a sensible floor on it.
thank you!
30hz is crazy!
all i want to get is 37hz so i can get LFC to work! (the actual minimum is x2 the max for lfc to work, the rest is just headroom).
at what range you have it now?
thank you!
30hz is crazy!
I got it to 30hz and and tested by framecapping to 31fps and it was fine. No flickering and no problems letting it free-run up to 75fps/hz either. It really is panel lottery but you can try a different interface (DP or HDMI).
I thought it was x2.5. I had some flickering at one point while set at 30hz. If I bump it to 37hz will LFC still work?
Edit : flickering at 37hz too.
Do i just edit the range in CRU and test with a benchmark? I get flickering when I set it to 30 and watch a 1440p youtube video.
Yes but you need to limit the fps to make sure a low frequency is tested.
no manual.Guys, I'm in the process of returning mine, the rainforest are coming for it tomorrow. Was there a manual in the box? I can't remember but looked everywhere and can't find it
Ah phew. Aye, thats what i found. Hah, if only i'd asked here earlier would have saved me tearing the room to bits trying to find it.
Disk
Base
Dlink
HDMI
Power.
