- 1 Dec 2015
@Kev1eighty7
That's a damn good price , mine was £520 months ago for the 11gbps version .
I run 8 pack kit at 4000hz , dropped down to 3800hz due to 5% error running mem tests over 2 hours . Min frame rate is about 5+ higher .
Not much difference with normal gaming but if your running 4k were every frame counts and VR to keep frame rates high and smooth as possible , I'd pick it . Rocking a gtx 1060 on a. 1080p wouldn't bother .
Plus you've got help of 8 Pack with the ram for any advice and clocking it
You also get 2x 140 pure wings installed at the front . Would move one to the top rear and the other one to the bottom . The two silent wings at the front to use that high static pressure to drive air into the case . That way you'll be running possitive pressure to avoid dust build up in the case . You could move both pure wings to the top , but run them at a very slow speed to keep possitive pressure
Another train of thought .
Keeping the Bequiet range but the new nice pure 600 with 5.3" bay in the front . And since 250watt /TDP Dark Rock Pro 3 can't fit and the Dark Rock 3 190watt would have to work a little harder but would fit, there's the Dark Rock TF which is 220watt/TDP. Has 2x 135mm silent wings , ones have only one or 135mm and 120mm . Has the benefit of blowing air directly o the VRMs which is a very good feature , specially on coffeelake systems and is 135mm tall so would fit and over the ram modules.
Will also cool down the NVMe drive as well
Plus would actually look pretty neat
My basket at Overclockers UK:
- 1 x be quiet! Pure Base 600 Midi Tower Case - Black Window= £84.95
- 1 x be quiet! Dark Rock TF CPU Cooler - 135/135mm= £74.99
Total: £172.24 (includes shipping: £12.30)
Helps case is on sale so makes up for the cooler not being
Move the single fan to the top so will be having 120& 140mm haunting - keep it linked up to case fan controller , lowest setting and then the two silent wings at the front - set max speed 80% constant as they are quiet and jobs done
