Anyone ever had issues with ETS2 and RivaTuner Statistics? I've just had to uninstall RTSS as it was causing my game to freeze for a second every so often. Never used to be an issue when I played in the past.
Having to try reinstalling. Since playing again, my game is having some kind of stutter/spike issue. It'll spike from 60 to 67FPS every so often with vsync turned on. Tried without vsync but still does same. Happens on all graphical settings and an unmodded profile is the same.
I used a steam game mover to move it from my HDD to SSD, so I wonder if it messed up somewhere. Hoping a reinstall can fix it.
I gave this a go, it was pretty relaxing until it came to reversing. NOPE uninstall run away burn that thing with fire.
That's the joy of ETS2, the reversing. Just takes time, soon get used to it.Was it attached to MSI and were you monitoring a lot of things ? That can cause issues with a game. I use MSI with RTS and only monitor my gpu fan rate, as I had a problem with it a little time back. Its sorted out now, but you know we all get paranoid after something goes wrong, gaming wise.![]()
That is probably the cause of the game issues. Best not monitor too much, knock each off one at a time to see when things get better. But to be honest, don't bother too much. 'Speccy' gives you an oversight with no drawback issues. Not as good, but the bare essentials.Yes it was. I think I was watching all 8 cores temps, GPU power, usage, temps, FPS and RAM. Not sure I had anything.
they all integrate nicely into one big game and the jobs/locations all just come up as you progress?
Thanks![]()
Works exactly like this. Only loading screen will be if you take a ferry and the initial loading of the game. Everything flows very nicely.
Correct. You could take a 3000 mile journey with the right mod and never have one loading screen aside from ferries.
